Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 64
Thread: Just bought a new amp, distribution block and wiring. Now I have questions.
  1. #41
    May 2006
    Calgary, Alberta
    Wow, thanks a lot. I forgot to mention, I did check Best Buy and a&b Sound as well. I don't think they had them, I'll try again today.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  2. #42
    May 2006
    Calgary, Alberta
    Nobody has high amp fuses. I have to try my luck at small install shops this week but I did pick up a 4 gauge amp kit from Cash Converters today as well as a new distribution block, and the install kit came with an inline fuse so that's one less to worry about. So now......lacking the fuses, here's what I'll do.
    1. 4 gauge power wire from battery to distribution block.
    2. Stock inline fuse in 4 gauge wire, whatever it is. 80 amps I think.
    3. Distribution block with no fuses (no sound, I know)
    4. 8 gauge wire from distribution block to subwoofer amp
    5. 8 gauge wire from distribution block to speaker amp
    6. remote lead wire from computer to sub amp
    7. remove lead wire from computer to speaker amp
    8. 3 amps, subwoofer, distribution block and computer mounted in trunk
    Then when I get the fuses I pop them in and I'm ready to go.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  3. #43
    Nov 2005
    CT
    Sounds good
  4. #44
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Cardomain has tons and tons of them. 20's, 40's, 60's, 250's, all kinds.
    Want to:
  5. #45
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    knukonceptz has anl fuses of all sizes too as well as partsexpress (i think)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  6. #46
    May 2006
    Calgary, Alberta
    Ya, I might have to buy online, sucks to have to wait for shipping.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  7. #47
    Mar 2006
    Colorado, but Canadian!
    I buy everything online... or at walmart. Much cheaper, usually even with overnight shipping, it still comes out cheaper.
    1.9in x 2.9in -- 47mm x 73mm
  8. #48
    May 2006
    Calgary, Alberta
    I got everything and started installing today. After snaking the 4 gauge wire around everything and hiding it, I ended up using the full 18 feet of wire, but I have a new question. Can I ground the 2 amps on 8 gauge wire? Since they both have 8 gauge going to them from the distribution block, I can ground them on 8 gauge right? And there's a 40 amp fuse in one and a 25 amp fuse in the other amp, and the 8 gauge wire can hold a max of 52 amps, so it should be fine right?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  9. #49
    Mar 2006
    Good rule of thumb is ground using same or bigger awg wire. You should be fine.
    I I hope you mean ground each amp with 8awg wire, not sharing 1 8awg wire.
  10. #50
    May 2006
    Calgary, Alberta
    Quote Originally Posted by 2k1Toaster View Post
    haha ya, each amp to the same bolt with 2 different 8 gauge wires. I realized today the MTX amp only accepts 8 gauge, I didn't even clue in when someone told me that a week ago.
    By the way, I'm having a hell of a time crimping the ring terminal on the 4 gauge wire!
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. WTTF: Distribution block and wiring
    By CavityCr33p in forum Classified Archive
    Last Post: 11-06-2005, 10:37 PM
  2. Wiring and terminal block recommendations?
    By omehegan in forum Car Audio
    Last Post: 07-21-2005, 09:25 PM
  3. misc wiring questions
    By nsmoller in forum General Hardware Discussion
    Last Post: 02-09-2005, 01:52 AM
  4. Distribution Block Questions
    By beckkl in forum Power Supplies
    Last Post: 10-20-2004, 12:29 PM
  5. Recommendations for amp wiring kits...
    By hd54321 in forum Car Audio
    Last Post: 08-17-2004, 07:02 PM
