Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 64
Thread: Just bought a new amp, distribution block and wiring. Now I have questions.
  1. #51
    Nov 2005
    CT
    Quote Originally Posted by Maheriano View Post
    By the way, I'm having a hell of a time crimping the ring terminal on the 4 gauge wire!
    Vice Grips
  2. #52
    Mar 2006
    Colorado, but Canadian!
    Well for my 4awg when I put on a ring terminal, I just smashed it really hard with a hammer.
    Always works!
    1.9in x 2.9in -- 47mm x 73mm
  3. #53
    May 2006
    Calgary, Alberta
    Quote Originally Posted by 2k1Toaster View Post
    Always works!
    That's hilarious, that's what I resorted to today! The wire was already run through the firewall so it wouldn't reach the ground. But I was parked in my underground parkade next to a wall so I just used the concrete wall to lay it against while I smashed it with the hammer.
    In one day I pulled all the 8 gauge power wire, ran the 4 gauge, got the fuseholder mounted, and the distribution block mounted. This morning I'm going to attempt to work on running the 8 gauge to the amps, grounding the second amp, getting the ring terminal on the 4 gauge and figuring out which wire in my Ampie is remote lead. Then I have to clear about 140 tools and garbage out of my car.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  4. #54
    Mar 2006
    Sounds like you are almost there.
    Got to admit, In the beginning I didn't think it would ever happen after reading some of your first posts. But it seems as if you have learned, so you are forgiven.
  5. #55
    May 2006
    Calgary, Alberta
    Thanks man. It's the curse of having to know why.
    I'll post pictures when I'm done.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  6. #56
    May 2006
    Calgary, Alberta
    I just spent the entire day trying to open one of the ring terminals I hammered shut and then it fell off the wire. I'm going to use the 4 gauge wire to ground the Rockford amp, why not right? Might as well.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  7. #57
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    When possible, I prefer to put the ring terminal in a vice, and secure wire into it while closing the vice. I'll vice crimp it secure enough to keep it from wanting to slip off. I'll solder and heatshrink all of my terminal connections to finish off. Never had one fall off yet.
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
  8. #58
    May 2006
    Calgary, Alberta
    One last question. How do I hook the subwoofer to a 2 channel amplifier? It's got +/- for speaker A and the same for B. I looked in the manual, it just says for single speaker setup, to hook it to the speaker A terminals, but won't I lose whatever bass is supposed to be going to speaker B in 2 channel sound? I don't know if that single speaker setup they were describing was for a subwoofer or just one speaker.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  9. #59
    _
    Mar 2004
    Little Elm, Texas
    If it's telling you to hook it to connect a single speaker to a single channel, the amplifier apparently isn't bridgeable.
    In the owners manual, there should be something that tells you how to wire in mono or bridged mode.
    It's probably something like A+ and B- (it could be reversed - that's why you need to check the manual).
    What brand and model is this amplifier?
    Jan Bennett
  10. #60
    Nov 2005
    Instead of using crimp terminals wouldn't those terminals that use the allen screws work as well? Thats what I used for my 0 and 4 guage wiring... Unless theres a good reason for not using them aside from them being almost 5 bucks each.
    Like these from stinger:
    1999 Lexus GS300- (going VIP)
    1993 Lexus SC300-Turbo (Totaled by idiot driver)
    1996 Lexus SC400- (Totaled by brother)
    1972 Datsun 240Z- (WIP)
    1994 Toyota Camry- (sold)
  1. WTTF: Distribution block and wiring
    By CavityCr33p in forum Classified Archive
    Last Post: 11-06-2005, 09:37 PM
  2. Wiring and terminal block recommendations?
    By omehegan in forum Car Audio
    Last Post: 07-21-2005, 08:25 PM
  3. misc wiring questions
    By nsmoller in forum General Hardware Discussion
    Last Post: 02-09-2005, 12:52 AM
  4. Distribution Block Questions
    By beckkl in forum Power Supplies
    Last Post: 10-20-2004, 11:29 AM
  5. Recommendations for amp wiring kits...
    By hd54321 in forum Car Audio
    Last Post: 08-17-2004, 06:02 PM
