Results 1 to 10 of 13
Thread: Sub Enclosure Slot port
    Sep 2005
    UK
    Hi,
    I have a JL 10 W7. The recommended ported enclosure for this is a slot. Does anyone know anything about this and ported enclosures in general, how do you know the size of the port and where to put it?
    Jul 2001
    The port area should be listed. Rectangular area is calculated by width x height. You can put the port anywhere on the box but people usually put them on the baffle face.
    Constant Bitrate chuyler1's Avatar
    Feb 2006
    Massachusetts
    If you visit JL Audio's website they will give you the exact dimensions for creating a slot port enclosure.
    2003 Mazda Protege5 -- Clarion/DLS/Eclipse
    Click here for install photos!
    _
    Mar 2004
    Little Elm, Texas
    just backing up what the others have said!
    do you have a length for the port as well?
    Jan Bennett
    Sep 2005
    UK
    thanks for the response guys. I realise that jl have the dimensions for a slot port but I was trying to get an understanding as I am wanting to create a customer fit box. So is it the port length that is important or the port area (ie the size of the hole?)
    _
    Mar 2004
    Little Elm, Texas
    all of it.
    I understand wanting to keep it all custom.
    You really need to keep the port as they have recommended.
    Jan Bennett
    Sep 2005
    UK
    OK so if the port area and the port length are both key, what is stopping me from making the port sqaure as apossed to a slot?
    _
    Mar 2004
    Little Elm, Texas
    I don't think there's a difference in going with a rectangular port v. a square port.
    Make sure the face of the port is tapered to cut down on port noise.
    From my understanding, a circular port will cut down on noise the most.
    Jan Bennett
    Jul 2001
    You're supposed to not bypass a 3:4 ratio of the length of the sides. Try not to make the lenghs multiples of eachother and you'll be okay.
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Here is a one-stop all you need to know on building box's forum:
    http://www.caraudio.com/forum/forumdisplay.php?f=25
    Good luck....
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  1. anyone using FIR port on EPIA M board?
    By stimps in forum Input Devices
    Last Post: 04-25-2009, 09:29 AM
  2. RR forgets GPS port!!!
    By eduardovdr in forum Road Runner
    Last Post: 07-17-2005, 05:11 PM
  3. Replies: 4
    Last Post: 07-04-2005, 04:38 AM
  4. flush mounting slot loading drive
    By residentalien in forum Fabrication
    Last Post: 12-29-2004, 05:50 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 08:48 PM
