Results 1 to 9 of 9
Thread: amp
    Apr 2006
    PA
    amp
    i have a kenwood 800w amp (gm-7100m) powering my sub. i deliver pizzas n tht means i turn on/off the car every 5 to 10 mins for like 6hrs a day, is there a possibility of screwing up my amp cuz of tht. if there is wud a switch on the remote signal wire do any gud or wht other way cud it b to turn on the amp only wen i want to
    Mar 2006
    Colorado, but Canadian!
    <rant>
    Well grammer is key to people understanding you. Luckily, I get it, but others are not as patient.
    Here is an excerpt:
    gud == good
    wht == what
    cud == could
    b, I'll let it slide...
    wen == when
    And it is a question, so a "?" is in order.
    I redirect you to the following link for future reference: Punctuation & Grammar FAQ
    </rant>
    <answer>
    I deliver chinese food myself, and my computer is constantly being put into standby, and turning off the amp. It works fine. Obviously, the more you turn it on/off always effects the products life use, by heating and cooling, and heating and cooling, and then relays being worn out by switching the power, and so on. It should not make any real big difference.
    </answer>
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2006
    why not just turn down the music while your in residential areas? why turn it completely off? just wondering
    Mar 2006
    i delver china foods n mi comp is go S3 all time, n bring wit it teh amp. It wurks gud. if u flip on/off, it cud break, but not much. wht u think bout mi grammar?
    Mar 2006
    Quote Originally Posted by BDVirus View Post
    When you deliver, you can't always keep your car running. I have remote start so I activate that, then take my keys and lock the doors for short runs, but still, it is a waste of gas. Not a question of disturbing the customers, more like neccessity of shutting the power off.
    Nov 2005
    CT
    Why not get a 2 way switch and have it so in one position it gives constant +12 and in the other position its switched with the cars aux. That way when you use your car normally the computer/amp goes on and off with the car and when you delivering you can have the computer/amp stay on independently of the car.
    Falls Church, VA
    The OP doesnt have a carPCat all. Its a general car audio question which will lead to a poor install cause.
    Nov 2005
    CT
    Quote Originally Posted by Will Albers View Post
    Thats why I said "computer/amp".
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    Quote Originally Posted by 2k1Toaster View Post
    2 meny pereods comas n sentansays
    It's hard to be incorrect. ..LOL
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
  1. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 09-05-2012, 11:43 AM
  2. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  3. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  4. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 08:29 PM
