Turn the radio off, then hold in the function button. It's in the same menus for setting your clock.
I cannot switch to AUX by pressing Source?
Only the Tuner and CD Mode can be used. I have the DEH-P4600MP and the CD-RB10 IP-BUS to RCA adapter. Everything is hooked up properly but I still cannot select AUX on my deck. The manual says that i will have to activate it if the feature is turned of (see pic below). It says to hit funtion untill the option to turn AUX-IN on displays. But there is no such option when in CD mode or Tuner mode. I have also tried holding the Source down switching it on and off and no setup menu appears. Does anyone have this problem or a solution for it?
Thank You,
http://img66.imageshack.us/img66/8048/switchonop8.png
http://img515.imageshack.us/img515/2866/sourceonjp7.png
It worked thank you its been driving me crazy
Your answer was a great help for me to set my aux. Now I'l like to know how to make the telephone function work. Thank you and Semper Fi
