Results 1 to 9 of 9
Thread: Question: Best subs for rock music
    Aug 2006
    La Jolla, CA
    Hey...I'm looking to put in one or two subs, probably one, and I mainly listen to rock music. I've heard going with a 10 will give me a tighter bass response which is good for that style of music. So, my question is, do I get one or two, and which ones do I get? Also, what amp should I be looking at? Finally, I do listen to rap occasionally, so if possible, what will give me that good rock sound along with decent bass for rap/hip hop? I don't want to spend a ton of money on this project. Thanks!
    Falls Church, VA
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by qvplite View Post
    a properly built box and sub will be able to play all your music effectively. i guess it's more of a question of:
    what kind of car do you have? whats your budget? do you want soundquality or spl (volume)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    FAQ: What speakers/amps should I go with?
    as well as the link that Will posted.
    Jan Bennett
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    I have found it more about the box type (sealed, ported), than the speaker. I have found that rock sounds better on sealed boxes, because it is usually a quick kick drum. Rap music sounds better on ported, but even then, it has to be tuned correctly. for ported: if you are trying to design it yourself, keep your box's resonant frequency high (like 60hz) to give the sound more of a punch. ported is louder, but can easily sound bad. Build it out of wood so you can redesign it. good luck.
    Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
    Jul 2001
    No, that would be bad. You want the TUNING to be 60Hz, not the resonant frequency. If the resonant frequency as 60Hz and there was enough pressure in the box, it would explode violently.
    Jun 2004
    Virginia
    Quote Originally Posted by Shadow View Post
    good catch. that's exactly right
    Dec 2004
    Los Angeles Ca
    awesome! then is say resonant freq as 60hz! and video tape it!
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jul 2001
    freakin jackass.. ONE spelling mistake in 669 posts and you get on me about it?
  1. Low-budget SPL Subs
    By SuprchargdMazda in forum Car Audio
    Last Post: 05-24-2006, 02:33 AM
  2. Soundblaster not pushing my subs...
    By 3onDubs in forum Car Audio
    Last Post: 11-21-2005, 04:27 AM
  3. Help hooking up subs and amp? Need advice...
    By jedi7001 in forum Car Audio
    Last Post: 05-17-2005, 01:28 AM
  4. FS: 2 mtx 10 inch subs and 400 watt amp with box
    By xdjxklusivex in forum Classified Archive
    Last Post: 02-25-2005, 03:41 AM
  5. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 09:08 PM
