Results 1 to 9 of 9
Thread: Will this sound card work?
    Variable Bitrate polo6979's Avatar
    Aug 2006
    Atlanta, GA
    Is this a good card to use if you are going to use an amp?
    http://www.newegg.com/Product/Produc...82E16829121126
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
    _
    Mar 2004
    Little Elm, Texas
    am I seeing that right?
    it only has a single left and single right output? So you could go to one two channel amplifier....only.
    note: for questions like this, please start a new thread, I split this out from the thread you originally posted in.
    Jan Bennett
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    The RCA closest to the 'top' is SPDIF. Probably out, whereas the white is probably in. The analog is part of a 'breakout' cable which is shown in some of the pictures.
    Read the review posted on Newegg. It starts off by saying the software doesn't work properly, so automatically it might not be so great.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    if your running a single amp then stereo output froma soundcard shouldn't be a problem. also if your amp has pre-outs then you can run a multi amp setup with a single set of rca outs. for the money though you should look into the silverstone dac. do a search about it on the forums and you'll find a link to a really good review/comparison of that unit.
    will cost you about $100
    edit:
    i did the searching for you:
    http://www.mp3car.com/vbulletin/show...187#post908187
    and here is the dac:
    http://www.newegg.com/Product/Produc...82E16812162002
    http://www.newegg.com/Product/Produc...82E16812162001
    it's actually the same price as the m-audio card
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2006
    Colorado, but Canadian!
    That's a lot of RCA's off of one connector!
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2006
    So 12 different channels to get sound out of? That can't be right...
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    8 channels out so will be 7.1. no doubt you can run it in anything 2, 2.1, 4.1 etc etc up to 7.1 though.
    May 2005
    Conyers, GA
    This card is designed for PRO use in studio and home studio environments. It's really NOT the right card for in-car use unless you are planning on having a few different things going on at once.
    "Two analog inputs and eight analog outputs plus coaxial S/PDIF I/O"
    http://news.harmony-central.com/Newp...-Ships-US.html
    I think Newegg has their caption wrong. This doesn't look like it's setup as a 7.1 card at all.
    Mar 2004
    Bristol
    just read the title: M-AUDIO 9900-40767-00 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - Retail
    has RCA out so i like it. (i hate 3.5mm jacks)
  1. where can I find low profile sound card?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-04-2006, 01:05 PM
  2. Sound only coming from one port of the sound card.
    By Maheriano in forum General Hardware Discussion
    Last Post: 08-27-2006, 09:21 PM
  3. creative x-fi sound card rules
    By pradecki in forum Car Audio
    Last Post: 05-31-2006, 02:30 AM
  4. setting sound card volume
    By cheesyhoward in forum Software & Software Development
    Last Post: 10-17-2003, 04:11 PM
  5. adding another sound card??
    By moahdib in forum General Hardware Discussion
    Last Post: 04-25-2002, 06:57 AM
