Results 1 to 8 of 8
Thread: Carputer and 2 amps
    May 2005
    Carputer and 2 amps
    I know we can hook up one amp to the carputer. But what about 2? I have a 4 channel and a 2 channel for the sub. If it couldnt be done i might have to run it through a hu and do it that way. But id rather keep it as a carputer running the audio. Any thoughts?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    -active x-over
    -soundcard with at least 4.1 chans
    -your amps may have pre-amp outs, you could connect an rca from the outs of one amp to the ins of the second
    -dsp processor like the alpine pxa-h701
    -rca y-adaptor
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by scott_fx View Post
    -active x-over
    -rca y-adaptor
    In a case where you might use an RCA Y adapter, would you be splitting the output voltage of your soundcard between the two amps?
    Dec 2004
    Los Angeles Ca
    as i understand it:
    No, the 2 voltages in parallel are equal. However many outputs you put in parallel, they will all have the same voltage across them.
    However, you can only draw so much current, and if you go into 2 inputs from one output, the amount of current that can be drawn for each output is cut in half.
    so..in reality... i'm not sure.. my brain is fried
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jun 2005
    chicago, Illinois
    Scott, you are correct. When working with parrallel, voltages are equal but the output of current is divided in proportion to the device. So in this case the current would be divided in half if it were to be to use the rca Y adapter. I'm not sure how much of a difference this will affect the output because the all amps are current amplifiers where the gain control is a voltage amplifier.
    PROGRESS:
    Feb 2005
    Barrie Ontario
    I hate to be hijacking the poor guys thread, but it's still kinda relative...
    Would a line driver possible solve this? Assuming I come out of CarPC, into the line driver, then a Y adapter (as the line driver has only one out) and then to my amps, or will it make a difference?
    Dec 2004
    Los Angeles Ca
    i'm not sure...but you can get a line driver/active x-over and that will definately work
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    M10k
    My Car Pc Install
    My Boat Pc worklog
