Results 1 to 8 of 8
Thread: Ported vs. Bandpass
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Ported vs. Bandpass
    I have 2 JL W3v2 Dual 2 Ohm subs in a ported box (don't know what hz, bought i before i knew about them) and i'm planning on getting a new box and i can't decided if i should go with another ported box ( if so what should i have it tuned at?) or if i should go with a bandpass box (same goes for it). I listen to rock, but i like to put in a good bass cd to show off and get the most out of my subs.
    Right now i have a profile 1000m amp powering them wired down to 2 ohms. That would give me 250 rms and 500 peak running to each sub which is a perfect match. Thanks alot, Drew
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    Before tuning a ported box you should know the resonant frequency of the car it is going in and for the impact I like a bandpass but the lower freq tend to sound like mush as most notes within some lower registers sound the same to me
    "A rose by any other name is still a flower"
    Mar 2006
    Iowa
    Quote Originally Posted by Pathos View Post
    How would i find this out?
    Jul 2001
    Pathos, you mean the cabin boost frequency, not the resonant frequency. This is the frequency that the cabin of the car helps to accentuate the most. You can find this out by getting a cheapo SPL meter from RadioShack and testing at low volumes with tones to find out what frequency is boosted.
    Also, just as most ported boxes are larger than sealed boxes, most bandpass boxes are larger than ported boxes.
    Mar 2006
    Iowa
    well i think i'm going to stay with a ported box. is there a reason that my subs don't sound as good when i have my trunk open and am listening to them (standing by them) as my friends alpine type r's in a sealed box? How do i fix it?
    Jul 2001
    ...because your box is designed improperly maybe? Generally subwoofers aren't meant to be listened to in close proximity. Your trunk has a pretty drastic effect on your speaker whether or not you realize it.
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by Shadow View Post
    That's the biggest reason right there. Your trunk acts like a speaker box as well.
    Low Bitrate feral's Avatar
    May 2005
    Melbourne
    I can reccommend Bassbox 6 pro if you wish to design your own enclosure
  1. Replies: 2
    Last Post: 04-10-2006, 11:09 PM
  2. ported box for type r
    By Risk_ldp in forum Car Audio
    Last Post: 02-25-2006, 01:18 PM
  3. 8" ported or 10" sealed sub? Limited space.
    By EVOgasmIX in forum Car Audio
    Last Post: 02-23-2006, 03:47 PM
  4. Building ported box-need help...
    Last Post: 02-15-2006, 08:34 PM
  5. 2 12in RF Punch Z's with ported R/T box
    By Redmachine in forum Classified Archive
    Last Post: 07-19-2004, 08:24 PM
