Results 1 to 3 of 3
Thread: RCA output
    Sep 2006
    RCA output
    Hi to all members, Pls give me some info about the RAC output, I have HU DEP-P8650 and the 3 RCA output is 6.5V, my Amp is MRD-M605 and the input level/gain is from 0.1mv up to 8v. I am new for the car audio setup, I need ur help to set my Amp, how many volt is the best setting to this amp. chers!!!!
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Sep 2006
    RCA Output
    Hi Scott, thank u very much for ur help, now I set my Amp gain in a very best setting, now I can not heared the clipping, There was a lot of clipping and I try many things to do to remove that clippings, in the first place i used gage 8 power cable and my freind said my cable is very small to my amp, instead to buy a gage 4 cable, I bough another gage 8 and run it again together with the old one. But the clipping is still there because I don know how to set the gain, I though is if u put in the lowest Volt should be better, but when i hook up the volt metter as u said i saw the execieve current volt coming out. Actualy I already have test tone CD coming from my freind but I don know how to use it,( ''MY DISC'' The Sheffield / A2TB Test Disc ) now I know how to use this, Thank u again Scott CHERSSSSSS!!!!!
  1. Replies: 94
    Last Post: 09-13-2011, 06:59 PM
  2. Is all coax/optical spdif output created equal?
    By Choser in forum General Hardware Discussion
    Last Post: 12-19-2004, 03:48 PM
  3. VGA vs RCA & Touchscreen vs other
    By integsrtite in forum LCD/Display
    Last Post: 12-02-2004, 07:07 PM
  4. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 05:00 PM
  5. Sound Card With RCA Outputs?
    By gguy in forum General Hardware Discussion
    Last Post: 12-03-2000, 01:08 PM
