Results 1 to 10 of 12
Thread: Why do my amp switch off when I drive???
    Sep 2006
    Exclamation Why do my amp switch off when I drive???
    In my Uno I have 2 x 12" 1000w DVC Pioneer subs (to see what they look like go http://www.howhotismycar.com/?i=4470) connected to a 1200w 2 channel Starsound amp (both subs bridged to one channel) + 2 x 500w starsound 6x9's connected directly to my Wharfedale Mp3 frontloader. When I installed my sound it played perfectly for about 2 months, but now the problem is that when the car stands still and idles the sound plays perfectly at high volume, but as soon as I start to drive, it goes soft and most of the time the subs hardly play just the 6x9's play normally. People told me that the amp is too small for the subs and overheats (that's somewhat true, because the amps gets very hot), but why doesn't that happen when the car isn't driven??? Someone also told me that it's my altinator regulator. Can someone help me with advice, before I have to spent unnessacery money.
    Aug 2006
    Spring City, Tennessee
    sounds like the addition of your aftermarket audio has taken its toll on your voltage regulator circuit on your alternator.
    Which model Starsound amp do you have installed?
    _
    Mar 2004
    Little Elm, Texas
    have you checked your grounds?
    I'm not experienced with the brand of amplifier, however, after a quick google, they look extremely generic. usually meaning they are a knock off and have much lower quality components.
    also, to have a set of 6 x 9s with a claimed power rating of 500 watts is a bit over the top and quite honnestly, difficult to believe.
    I'd venture to bet that your equipment is having problems doing it's job. Double check all of your grounds and make sure they are 100% solid and are making a good connection.
    Do you have any problems with any other components in the car? any other electrical issues?
    If it's JUST the audio system giving you problems I wouldn't think it would be the alternator.
    How big is your alternator? Have you upgraded the big 3? are you still on the stock battery? how old is the car? how many miles?
    Jan Bennett
    Aug 2006
    Red brings up some good points after i took a visit to the amp's site. The company does look a bit on the 3rd rate side....
    ::EDIT:: On your amp, when things go "quiet" Have you had a chance to pull over and look at your amp to see if its going into protection for some reason?
    Jul 2001
    Nobody's seen the obvious answer yet: Your amps switch off because you touch yourself at night.
    Right, said Red.
    Jan 2006
    Quote Originally Posted by Shadow View Post
    Right, said Red.
    What???
    Sep 2006
    Thanx. I found my problem: My grounds. The one connected to my amp was connected onto my back shock. As I started driving the shock moved and with that I lost my ground. I now connected it by myself to the car directly. The guy that did my installation for me was actually very stupid. Thanx for all your advice...
    Jul 2001
    There's usually a rubber bushing on the rear shock. That's why Red always recommends to not use anything factory as a ground.
    _
    Mar 2004
    Little Elm, Texas
    :d
    Jan Bennett
    Sep 2006
    Go Red, you clever child!
  1. Western Digital buyers beware!
    By tj!2k4 in forum General Hardware Discussion
    Last Post: 11-26-2005, 01:17 AM
  2. MB870 & Slimline Floppy Drives
    By McGreggor in forum General Hardware Discussion
    Last Post: 11-09-2005, 07:32 AM
  3. AMP wont turn ON!! HEELP!
    By pdjafari in forum Car Audio
    Last Post: 10-15-2005, 08:43 PM
  4. 2.5" drive help?
    By IntellaWorks in forum General MP3Car Discussion
    Last Post: 10-03-2005, 08:36 AM
  5. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 01:24 PM
