Results 1 to 10 of 13
Thread: i need help finding the right amp
    Sep 2006
    ok this is an extention to a question i posted earler. what i need to know is, what is the best amp to power a pair of pyramid hyper pro 500watt speakers. i am trying to build a decent system on the cheap. ive been shopping mostly on cardiscoutstereos.com and im debating between a more expinsive lanzar model found here: http://www.lanzar.com/itempage.asp?MODEL=VIBE236 or a cheaper pyramid model found here: http://www.pyramidcaraudio.com/itemp...p?model=PB717X i'm also planing on buying an amp to power 4 300 watt pyramid 3-way speakers. to let me know your reccomdations they are greatly appreaciated
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Are those ratings in RMS? What's the Ohm rating on the speakers?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    much better then the two you listed: http://www.edesignaudio.com/edv2/pro...products_id=45
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Sep 2006
    all the speakers are 4 ohm and the watts i gave you are max, i cant find a listing for rms. what is the lowest price for that amp you suggested, like i said im on a tight budget.
    Dec 2004
    Los Angeles Ca
    pm sent with a special price ;-)
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Newbie mtrydoc's Avatar
    Jul 2006
    Seaside,Ca
    I would follow Scott FX advice. The Elemtanal Design Stuff works great. And the Price is outstanding.
    MtryDoc
    2006 Nissan Titan LE 4x4
    Magetic Blue Crew Cab
    4" Lift by PRG Productions
    Infill T3 HU
    Rainbow Sound Line SLC
    ED Nine.1 Pushing 10v2 Sub
    ED Nine.4 Pushing Components
    "A Wife That Really Loves Me!!"
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    Added to favourites
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by jschrauwen View Post
    Added to favourites
    off topic...i haven't forgotten about you...i just can't find the speaker grills. i know they are around somewhere.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Sep 2006
    even at that price it is way too expinsive im looking to spend 60-100 on the amp and what is better about that amp over the lanzar amp
    Jul 2006
    Quote Originally Posted by emttravis View Post
    Contradicting request - "trying to build a decent system on the cheap". How about "a cheap system on the cheap" or "a decent system on the decent $"? Both units look to have some pretty inflated specs. Either should suit your needs but since you're already started with Pyramid speakers might as well continue with same manufacturer. I've never used either. The bottom line is that you usually get what you pay for - usually.
    John
    Quote Originally Posted by scott_fx View Post
    Thanks Scott. It seems that 3.5" speaker grilles are even rarer to find than the 4" ones.
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. Brand new AMP, Busted..
    By Biograph1001 in forum Car Audio
    Last Post: 02-19-2006, 11:54 AM
  3. amp pop
    By dan__wright in forum Car Audio
    Last Post: 06-16-2005, 05:24 AM
  4. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
  5. Amp setup. Heat concern.
    By d_sellers1 in forum Car Audio
    Last Post: 07-09-2004, 10:58 AM
