Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: questions on runnin another amp to my system
  1. #11
    Low Bitrate frugmonkey's Avatar
    Jun 2006
    west yorks england
    how do japs make 50 watts into 260 watts! the mind boggles!!!
    Progress: ~99%
    Fitted, Running.
    boot install to tidy when better weather arrives
  2. #12
    Cip
    Cip is offline
    Sep 2006
    RI
    y have em if u edont make em scream?
  3. #13
    Falls Church, VA
    Same goes for your car engine? Rev it to max each time?
    So you are telling us that you are more interested in total volume than sound quality?
    Ya know, you can turn on the LOUD feature of your headunit and raise the bass and treble controls to max (do the same with your gains) to get more volume out of your system
  4. #14
    Cip
    Cip is offline
    Sep 2006
    RI
    well what happened was when i did install them in my car i didnt notice any difference between them and the factory setup i figured itd be louder and wouldnt distort at max volume but it did, but yea i want loud and clear
  5. #15
    Low Bitrate Epon's Avatar
    Oct 2005
    So go out and buy speakers that can handle higher RMS wattage. And blow a grand.
    2004 Ford Mustang
  6. #16
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Quote Originally Posted by Epon View Post
    He'd need a headunit or amplifier that could actually put out higher RMS.
    Replacing ONLY the stock speakers with aftermarket speakers will probably make your system sound quieter, but clearer. To fully utilize aftermarket speakers, you need (at least) a better headunit, or beyond that, an amplifier with ratings that match the RMS of the speakers you're using.
    Peak values are smoke and mirrors. Sure, it can handle 260w peak, for about a fraction of a second before the coil melts.
  7. #17
    Cip
    Cip is offline
    Sep 2006
    RI
    we'll i have a pioneer head unit the p-3800 i think the model is i kno its 3800 but i dont kno the first letter
  8. #18
    Cip
    Cip is offline
    Sep 2006
    RI
    Quote Originally Posted by Jahntassa View Post
    I was thinking of adding something like this, will a higher rms on the amp make the speakers louder???
    Standard features
    High speed MOSFET switching power supplies
    Thermal, DC offset, reverse polarity and short circuit protection
    Built-in blue LED top panel illumination
    External LED/Fan power jack
    Built-in high performance, variable 12 dB/octave 2-way active crossovers
    Switchable 8 dB bass EQ function
    Remote subwoofer level control function
    2 or 4 channel input capability (A1004)
    Expandable architecture features include buffered stereo full-range RCA output jacks (all models) and external
  9. #19
    Falls Church, VA
    Start with a decent head unit. If there is not enough power there to get the volume you are after, THEN add a HIGH quality low power amplifier (budget). Do NOT look at higher power as better.
    What is your max budget?
  10. #20
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    You'll probably ruin your imagine and get some funky noise cancellation issues with a 4way or 5way. You REALLY have to know what you're doing. Stock speaker locations wont do
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. adding a amp to factory bose system
    By wyldbill in forum Car Audio
    Last Post: 08-21-2005, 01:36 AM
  3. adding a amp to factory bose system
    Last Post: 08-20-2005, 05:23 PM
  4. Questions on a new system
    By kameleon in forum Newbie
    Last Post: 07-05-2004, 11:01 PM
  5. Newbie Questions... Building my system
    By Fender2Martin in forum Newbie
    Last Post: 05-15-2004, 01:25 AM
