Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: questions on runnin another amp to my system
    Cip
    Cip is offline
    Sep 2006
    RI
    As soon as I get my new car, I will be putting my system back in! Im currently running 2 12 inch Alpine Type Rs being powered by a RF 900w Mono block. Ill be also adding underglow, and replacing the factory battery with a red top which was in my other car. I plan on buying a monte carlo which has a 104 amp stock alt. already. I will be swapping the front and rear speakers with 4-way pioneers in the front and 5-way in the rear. I was thinkin of adding a small amp just to push the speakers, but i was undecided if i wanted to add another one to push the subs also; Ill also be bypassing the factory amp! what would i need to add another amp and anyone kno any good small amps to add that are reasonably priced? Ill be wiring the big amp with this...
    Help, Please!!!!
    Jul 2001
    4 way = overkill
    5 way = beating a dead horse
    Why don't you get some nice 2-way components instead? It'll sound a LOT better.
    Cip
    Cip is offline
    Sep 2006
    RI
    i already have em, thats why, its true i wasnt impressed with the sound quality at all
    Cip
    Cip is offline
    Sep 2006
    RI
    but any other advice???????
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    So you're asking about what, a four channel amplifier? We can't really give you any reccomendations without the specs on the speakers your using, or what you consider a 'decent' price.
    Falls Church, VA
    Quote Originally Posted by Cip View Post
    Ya, read the stickies at the top of the forum. Specifically this one: Have Car Audio Specific Questions?
    Cip
    Cip is offline
    Sep 2006
    RI
    Quote Originally Posted by Jahntassa View Post
    Max power 460 watts
    5-way 6"x9" speaker
    Aramid fiber reinforced IMPP woofer with rubber surround
    Polyester fiber semi-dome midrange
    Power range 2-80 watts RMS
    Frequency response 25-30,000 Hz
    Sensitivity 93 dB
    Top-mount depth 3-3/8"
    Composite IMPP cone using interlaced aramid fiber
    Heat-resistant voice coil
    Glass-imide voice coil bobbin for higher power handling capabilities
    11 oz Strontium magnet
    Full-depth basket for longer excursion and richer bass
    1 5/8" Midrange balanced dome
    5/8" Tweeter
    3/8" Super Tweeter
    Woofer 160mm
    Max Power: 260 Watts
    Nominal Power: 50 W
    Frequency Response: 30-33,000 Hz
    Sensitivity: 91 dB
    Impedance: 4 ohms
    lets not worry about price, lets talk quality 1st
    May 2005
    Conyers, GA
    RMS (Nominal) power on those speakers is fairly low. An amplifier that can put out between 50-75 watts per channel should be fine. 'Quality' amps can be anywhere from $150 to thousands of dollars. I'll assume because of the speakers you have you're probably looking for closer to $100-$200, in which case some nice four channel amps to consider are ones by JL, Alpine, and others that i'm sure people will suggest.
    Cip
    Cip is offline
    Sep 2006
    RI
    how do i get them to run at max power? and if i add this other amp what am i gonna need? will it drain my battery? lemme kno! thanks
    Falls Church, VA
    more importantly, WHY do they have to run at max power?? Is it a race?
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. adding a amp to factory bose system
    By wyldbill in forum Car Audio
    Last Post: 08-21-2005, 01:36 AM
  3. adding a amp to factory bose system
    Last Post: 08-20-2005, 05:23 PM
  4. Questions on a new system
    By kameleon in forum Newbie
    Last Post: 07-05-2004, 11:01 PM
  5. Newbie Questions... Building my system
    By Fender2Martin in forum Newbie
    Last Post: 05-15-2004, 01:25 AM
