a kxdriver compatible soundcard with the kxdrivers installed will let you 'rewire' the card for as many inputs and outputs as you want (well...factoring how many i/o jacks are on the card)
Ok here is my problem. I have a four channel amp with four RCA inputs. At the moment I am using the onboard sound on my M10K clone. The line-out is currently going to my amp but I only get two channels obviously.
Now the M10K supports jacksense so I could convert the onboard sound so that line-out output the rear channels and line-in output the front channels. The problem with that is that I need line in because I use a Radio X-treme FM tuner and it outputs via line-out so it needs to be input somewhere in my system.
I also have a 5.1 Zalman USB soundcard but it doesnt have line in so I cant use it. When I have the USB sound plugged in the onboard doesnt work so I can have a mixture.
Is there a solution here that I am overlooking?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
