Results 1 to 4 of 4
Thread: help
    Sep 2006
    help
    Hello
    I just re installed my amp and speakers. I run a 4 channel setup, with 2 paralell speakers on the front r/l and channels 3 and 4 are bridged wit a small woofer.
    They only thing I did today wasinstall my new amp, and now there is no sound, yet there is a thump from all the speakers in unison, quite frequently. At first I thought it was a bad ground, but I couldnt find anythin to support that. my power cable it attached properly, however, in unison with the thumps, the power LED blinks. SO i dont know, any input would be HIghly appreciated. thanks.
    Elsewhere
    This forum is dedicated to CarPCs and installing them in your car.
    The car audio forum is dedicated to integrating your car audio system with your CarPC.
    For specific questions related to car audio equipment systems that do not include CarPCs, I would recomend checking out car audio specific forums:
    http://www.elitecaraudio.com
    http://www.carsound.com
    http://www.caraudioforum.com
    http://forum.sounddomain.com
    http://www.realcaraudio.com
    http://www.carstereo.com
    http://www.caraudiomag.com
    http://www.termpro.com
    http://www.the12volt.com
    http://www.talkaudio.co.uk
    http://www.caraudiosecurity.com
    et. al.
    There is a chance that someone on here might have an answer for you, I would just hate for you to wait around for it when I know you could get an answer much quicker on a dedicated forum.
    Good luck.
    How about the Wiki?
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    look for the LPF/HPF switch and put it to HPF or fullrange, cause now you have it set on LPF, for what i can tell from your posting.
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Jul 2001
    Could be low voltage on the remote line. I'd check the ground though.
