Results 1 to 10 of 18
Thread: USB DAC options
    _
    Mar 2004
    Little Elm, Texas
    USB DAC options
    Hey all.
    Seeing as how the USB DAC has become a popular option for some folks, I figured a thread listing the options out there would be beneficial.
    I'd like to set it up much like the 5.1 amps with digital ins thread, and the mini-itx threads on this board elsewhere.
    So show me what you have found!
    http://www.wavelengthaudio.com/ - This is by far one of the nicest DACs I've found. However, the price will cause some people to nearly stop breathing I'm sure.
    http://www.silverstonetek.com/products-eb01.htm
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Seeing as how I'm sure there will be much debate and discussion regarding these DACs, I figured a few words about them from various sources might be beneficial to some.
    What is a DAC?
    From the Stereophile Forums talking about jitter and USB DACs as well as USB two way communications for error correction. VERY good read.
    Jan Bennett
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    well i guess i'll start.
    this is the one i'm currently testing:
    http://www.ecp.cc/HPDAC.html
    we'll call it the 'douglas' hpdac. since this is a diy board you can use whichever components you'd like. I'm currently running burr-brown opamps and blackgate caps.
    also... since it's a diy board you can wire it with female rca's to connect directly to your amp. This will give you a digital signal within inches (or less) of your x-over or amp. If you are going the x-over route you can also think about cracking that active x-over open and wiring the outputs of the dac directly to the inputs of the x-over.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    I use the Silverstone USB DAC. It of course doesn't require a driver, just plug it in and it shows up as USB Speakers. You don't have to worry about turn on thump w/ most DAC's, as w/ the SS it doesnt turn on till it gets music to play. The DAC doesn't require in extra power... just a single USB cable will do comms and power. The sound is rich and clean.
    The problem most DACs (that have problems) have is that of IRQ's. On my setup I have 8 USB 2.0 powers onboard and a add on card, along w/ the normal basic interupts. When I first connected the DAC to this setup I had cracking and popping... after disabling a couple things in the bios I've lost all but a slight crackling every now and then. The fix is usually changing the PCI latency or changing IRQ's for the device.
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
    Aug 2006
    You can change the volume of the DAC using your front end, correct?
    Aug 2005
    Little Elm, Texas
    Correct!
    Setup:
    Dynaudio 240GT
    Zapco DSP6
    ADS DAC
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    Quote Originally Posted by RedGTiVR6 View Post
    *clutches chest and reaches for phone to dial 911* j/k. Amazingly resembles the prices my brother charges for the high current tube amps that he builds.
    *edit*
    Would the average person/carpc system be able to discern the quality difference between an $84 Silverstone and a $195 HPDAC? I don't even want to try and get my head wrapped around the Cosecant, Brick, or Ultimate DPU.
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
    _
    Mar 2004
    Little Elm, Texas
    The average person can't tell the difference between a MP3 ripped a 128 and the true CD source.
    However, it's like anything else in life. If it's something you are into, which we all have something, you know the differences.
    When you live and breathe something nearly every waking moment of your life, you can tell a difference.
    Jan Bennett
    Aug 2005
    Little Elm, Texas
    If that was the truth it would be a shame.
    Setup:
    Dynaudio 240GT
    Zapco DSP6
    ADS DAC
    _
    Mar 2004
    Little Elm, Texas
    why do you think the iPod has become so popular? Why do you think there are companies making millions off of selling mp3s that are much less than CD quality?
    it's because people don't know the difference and don't care to.
    Try and find a music store online, where you can download music files in HIGH quality.
    There was 1 that I was aware of, and even then, it wasn't 'HIGH' quality by many standards...
    Jan Bennett
  1. Found a new USB dac!
    By kingeorge36 in forum Car Audio
    Last Post: 01-04-2009, 04:29 AM
  2. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  3. USB hub does not always initialize on boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-29-2006, 04:41 AM
  4. Powered Hub, Lots of USB Devices! Will this work?
    By adamharrisuk in forum General Hardware Discussion
    Last Post: 05-15-2006, 12:00 AM
  5. Slot load, usb sound, fm/tv tuner, wifi, laptop and more
    By dmcdlrn in forum Classified Archive
    Last Post: 04-25-2006, 01:43 PM
