Results 11 to 20 of 26
Thread: Speakers turning on and off...?
  1. #11
    Falls Church, VA
    Factory amp or low impedence factory speakers
  2. #12
    Sep 2006
    Quote Originally Posted by blkwrx View Post
    Let me get this straight.
    1) HU is driving front and rear speakers
    2) Amp driving sub
    3) Front speakers cut out but back speakers and sub keep playing
    4) you replaced front speakers with no change
    My guess is the HU internal amp for the front channels is going bad.
    Correct, that's what I was afraid of. Is it worth it to maybe somebody try to fix it or would it cost the same or less to just buy a whole new unit? I really like the button layout of the JVC's and the user friendlyness but this is the third time that this has happened to me. I think it's time to look for a new brand.
  3. #13
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    I would pick a new HU. for as far as I know JVC comes forth of the same factory where sony's been made, so wouldn't get my hopes up too hight that fixing the problem will hold too long
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  4. #14
    Nov 2005
    CT
    Quote Originally Posted by FloydSoad View Post
    If its the internal amp its probably cheaper to buy a new hu.
  5. #15
    Jul 2001
    True story. The rear channels are reversed in the wiring harness but they're otherwise identical.
  6. #16
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    To save you some money.
    Trask the rear output.
    Make the rear output as the front. Swap the Pioneer currently from the back. Trask the stock speaker or just use it to cover the speaker hole in the back.
    So now you have the HU run 2 pioneer speaker in the front and the amp run the sub. That is all you need. A lot of people don't use rear speaker (and they refer to it as who need rear fill.)
    Okay although this forum has audio section, but only a few people know about car audio inside out. Most of us are just like you either has no clue or with very little. That is the reason the sticky advice you to get help else where that didicated to car audio. Eventually you will get the answer (maybe), but it will take time and probably wrong answer as well.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  7. #17
    Sep 2006
    Thanks for the help, still havent had any replies from the other websites in the sticky...Good idea MAtrixpc except that the rear speakers are 6x9 in a box (SUV) so that wouldn't really work to swap them out with the 4x6's in the front. although I could just spend a little bit of money on some components for the front, which would be cheaper than a new HU, and forgot about the rear speakers like you said. But then the rear channels could go out tommorow with my luck...
  8. #18
    Falls Church, VA
    Dont swap the speakers, swap the output of the deck. Hook up the rear speaker output of the deck to the front speakers. Do not hook anything to the front speaker output or the rear speakers.
    My guess is you will have the same problem.
    You need to run new speaker wires from the deck to the front speakers. Do not use the factory speaker wires
    What kind of car is it? Does it have a factory amplifier?
  9. #19
    Sep 2006
    So it might be the factory wiring to the speakers?
    It's a 94 blazer and it doesn't have a factory amplifier. All the power is from the deck and the amp for the sub.
  10. #20
    Nov 2005
    CT
    Its possible, and a lot cheaper to test than buying a new HU.
  1. Off - On - Momentary Switch?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 07-08-2003, 12:07 AM
  2. could someone please measure 4 points on his sproggy
    By felix99 in forum Power Supplies
    Last Post: 02-27-2003, 11:40 AM
