Do what Will said first, run new speaker wires from the HU to the speakers. If that doesn't solve the problem, you can do the swap.
My best answer is that it is the wiring for the front speakers. Maybe an internal break in the wire that through the suttle vibration makes and loses contact. I've had the same issue except for me it was a loose connection at the speakers but still the same symptoms.
Just my two cents.
Avengerki
PC Install: 85%
Car PC: Revo-Sys X300 Double Din: 1.3GHz Pentium
Software install and setup: 35%
Entertainment Package: 85%
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
If it happens to be the internal amp and I do decide to buy some decent components for the front, is the head unit going to have enough power to make it sound decent? It's rated for 52 watt max, 20 rms. Or am I going to have to invest in an amp to drive the speakers? I notice a little lacking with my 6x9's but if i'm only going for high end sound, will the head unit be enough?
If you invest in a strong compnent set for the fronts, you will need to give them an amplifier. The deck does not have enough power except for basic speakers.
50 watts RMS from a clean amplifier is all you need. More if budget permits. Do a decent 4 channel x 50 watts rms and you will be fine for your interiors.
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
