My laptop only has one MIC input, and no AUX line input. So, I'd like to know what options there are available besides a USB soundcard.
I'd like to get the Silverstone DAC or similar, but I need an AUX input.
Printable View
Have you connected a stereo source to see if the mic input is stereo? If it is, you can just turn the input sensitivity down.
would that sound quality be equiv to a dedicated AUX source?
Well, because it'd be passing through the mic pre-amp, even if you turned the input gain down...
No. You'd need a USB or PCMCIA solution.
If your motherboard or soundcard has an input for cdrom type audio connections you can wire up a headphone jack and use those as inputs. I currently use one for my XM radio due to my line in is used by my TV tuner and wanted to leave the MIC open for speech recognition.
Pinouts
http://www.epanorama.net/documents/p...udio_wire.html
Types of cables depending on your SC or MB header
http://www.pigselectronics.com/graph...rge/CDAUD2.JPG
The jack you'll need
http://www.goldmine-elec-products.co...es/G13562B.jpg
OR you can get one of these...
http://www.frontx.com/pro/p090b1_030p2.gif
http://www.frontx.com/pro/p090b1_030.html
@Custommx3
where did you find that jack? local radio shack came up short (big surprise).
look around on the fry's website, and they carry this:
http://image.ak.outpost.com/art/prod...343172.box.GIF
http://shop3.outpost.com/product/334...H:MAIN_RSLT_PG
would that work too?
