Results 1 to 10 of 19
Thread: How to power neon in sub box?
    Apr 2006
    I am building a sealed sub box, with two 12 inch neon tubes on the inside. What is the best way to power these neon tubes? Thanks for any suggestions.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i guess you could use another speaker wire cup to get power to the tubes. or just run wire into the box through a hole then silicone the hole up
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Apr 2006
    Where would I connect the power wires from the neon to?
    Dec 2004
    Los Angeles Ca
    the battery. better yet, add a relay that is switched on/off by the acc lead.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Apr 2006
    There is no way to hook it up to speakers or the amp? I really do not want to mess with the ignition wires...
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    You could do it if you have a relay. Wire the relay in-line with the remote-turn on lead from the radio, and power it off the battery line going into the amplifier.
    The relay would then be able to connect to the amp's remote-turn on and power the neons, without damaging whatever is providing the turn-on voltage.
    Dec 2004
    Los Angeles Ca
    err...isn't that what i just said?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    May 2005
    Conyers, GA
    Well, yeah, it was. I was just, y'know...expanding on it.
    "scott_fx's advice, now in High Definition!"
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    Quote Originally Posted by black06stang View Post
    no truly safe way, you could hook it up to your cigarette lighter if you wanted, but its not the safest way
    and get LED's they run off 12v anyway, then you wont need an inverter/transformer box (whatever they run on)
    Jul 2001
    No, you said acc lead, not remote turn-on wire
  1. Travla AC/DC power supply cable
    By Change in forum Power Supplies
    Last Post: 07-25-2006, 11:04 PM
  2. 12v Power Supply at MP3Car.com store
    By mykolJay in forum Power Supplies
    Last Post: 02-02-2006, 10:17 PM
  3. F/S: JL 12w7 Subwoofer with box!!! Pictures inside
    By neema12 in forum Classified Archive
    Last Post: 08-29-2005, 09:45 PM
  4. Darn ITPS! Need power help!
    By DJ-FrosT in forum Power Supplies
    Last Post: 07-16-2005, 08:40 PM
  5. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
