Results 1 to 5 of 5
Thread: What the heck just happened?
    Constant Bitrate Adam432823's Avatar
    Nov 2003
    S.F. Bay Area
    Angry What the heck just happened?
    So I needed to take my car into the shop and I didn't want the poor guy to get fried under the hood so I decided to discharge my cap (1.5F). I disconnected it from ground and ran the stereo to run it down. Seemed to work OK, nothing blew up or anything. Then I got my car back, completely disconnected the cap, put back the ground wire and then charged and reinstalled the cap.
    NOW I'VE GOT HELLA NOISE!!! Its insane. Everything is wired exactly as it was. The wires are in the same damn place. I can't tell if its ground loop or a bad ground, but like i said, same wires in the same place and my grounding is perfect. I can't figure out where the noise is coming from. Its the all too typical alternator whine that gets higher with engine revs. If I pull the RCAs from the amp, then the noise is gone. I really don't want to rip everything out to troubleshoot this, but unless anyone has any bright ideas, I guess I'm screwed.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    What kind of noise?
    Check you connectors on your cap? Maybe you got something dirty... who knows.
    Tidder
    Try RevFE
    Nov 2003
    S.F. Bay Area
    Well I haven't checked every connection yet... that's a load of work, but its probably in the works.
    Key on ACC there is a faint whine in the speakers. I'm assuming thats related to the fans spinning. Start the motor and there's hella noise. Its the scratchy whine that increases in pitch as you rev the motor. Buts its so way louder than anything I've ever heard... you could hear it outside the car.
    Sep 2003
    New Mexico, USA
    Ooooh man, that's horrible. I get the same thing thru my stereo until my carPC is actually powered on. Once it powers up, all noise is gone completely. Strange.
    I dunno, maybe someone else could jump in here and have some ideas of what your shop guy coulda messed up while fixing things that would cause that. What did you take it in for?
    Also, maybe try to bypass your cap for now, just to test?
    Tidder
    Try RevFE
    _
    Mar 2004
    Little Elm, Texas
    thread title edited to reflect the rules regarding language in thread titles.
    also, you might want to check this thread to help your problems: Induced noise/Ground loop trouble shooting guide.
    Jan Bennett
  1. Very strange thing happened this morning (alternator whine)
    By 96TransAm in forum General Hardware Discussion
    Last Post: 09-21-2006, 09:09 AM
  2. What happened to the SD Trunk Bundle?
    By BhashaZ in forum StreetDeck
    Last Post: 08-07-2006, 04:26 PM
  3. What happened to "Users viewing this forum/thread" at the bottom ?
    By frodobaggins in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-21-2003, 08:31 PM
  4. Whats happened to trimodalvoice
    By edie209 in forum Software & Software Development
    Last Post: 04-03-2001, 03:54 PM
