Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Water inside door panel!
  1. #11
    Oct 2004
    NY
    ha, matrix, I see you had a run in with sdashiki... most of his early posts were like in your thread.. he called everyone stupid morons, in the mean while, he was increadably "not too smart" himself...
    after a year or so he calmed down a bit & spends alot of his time here in off topic now, reporting the latest news he's read usually with links & his own "opinion"
    that guy is not to normal
    most cars when you pull a pair of low mounted speakers after a few years, you WILL see rust... the water cannot go directly on the speakers, but a lot of times it'll get wet from moisture being there, or in some cases splashing as water hits the bottom of the door... baffles only do so much, & you don't want to block the whole rear of the speaker or you'll really hurt the lower end response bigtime
    weep holes usually clog when dirt & water kinda makes a paste & clogs the drains... leaves & dirt are usually the cause
    most guys put those half cup baffles on wrong, they should usually go on the bottom end of the speaker, cause the water that hits a speaker does so from the bottom up, as splash, not from the top down, most guys put them on top like an umbrella, but that does nothing... again, in most cases...
    if you do decide to go that route... make sure there not sealed like a cup though, incase water does get in, theres an easier way for it to drain..
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by MatrixPC View Post
    At the end, I bought 4 baffles to protect the speakers.
    be extemely careful with these baffels.
    Many times, they stick out behind the speaker too far and the window will tear them when it goes up and down.
    Jan Bennett
  3. #13
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    I ask it once so here you go. Read it for your own entertainment.
    At the end, I bought 4 baffles to protect the speakers. I don't know what did the ashole who called me moron used. He had a matrix too.
    THAT WAS ME!!!!! But I was merely thinking to myself "who says SOAKED when referring to their car door's interior?"
    and I apologize, as I recently opened up my doors and saw some drops of water.
    honestly, I didnt think anything of rain in my doors cuz over the years I never saw a drop in any of my previous vehicles, and I just didnt think logically about it.
    ill eventually get myself some baffles.
    on the matrix tip, what did you use?
    PLUS I IS CRAZEEEEE! (used to say "Emotionally Unstable" under my name, sad to see Max Bitrate!)
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
  4. #14
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    I'm not sure where I saw, this but it was mainly used in kicks, but some people have used tupperware containers behind their speakers to help get an air-tight seal for optimal SQ. I'd venture to say that in 90% of cars this wouldn't work because of window clearance, but it would help waterproof the speakers.
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    I can't imagine you'd get NEAR enough air space out of that.....
    Jan Bennett
  6. #16
    Aug 2004
    Floreeda
    in my defense to my craziness in the connected thread....
    I was living in Phoenix, AZ at the time!
  1. FS-PC Water Cooling Gear, Hard drives Misc Stuff
    By belezeebub in forum Classified Archive
    Last Post: 04-12-2006, 05:55 PM
  2. 15" LCD 2001 Sierra 4x4 Ext cab
    By CPUFX in forum Show off your project
    Last Post: 07-21-2005, 09:17 PM
  3. Totall Off Topic.... (WATER BOTTLE DISPENSER)
    By KingsDude in forum Newbie
    Last Post: 05-12-2005, 11:01 PM
  4. Water Cooled carPC
    By Nicorolla in forum General Hardware Discussion
    Last Post: 01-25-2005, 03:24 PM
  5. gps inside engine comp.?
    By kalito in forum GPS
    Last Post: 02-24-2004, 11:57 AM
