Results 1 to 10 of 10
Thread: Is my HU dead?
    Apr 2005
    Queens, New York
    Is my HU dead?
    OK well today I totally rewired my entire car from CarPC to Amps...As i was pretty much all finished i went to connect my HU up but when I connected the Antenna to my HU a few sparks shot out....Now I noticed that my HU wont power on if the antenna is not plugged in. So i go to start my HU and I get NOTHING....could i have shorted my HU? It wont even turn on at all...Are there anyfuses inside the HU itself....I checked the inline fuse on the wires going to the HU and they are fine....My HU is a Panasonic...
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by Cheekz185 View Post
    What's the model number?
    Peace,
    Rafster
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Maybe you have to look at the car's fuse panels. Most of the time they are under the sterring wheel where you can find a fuse called "Radio" or similar term. Also, there are fuse panel under the engine pay (next to the battery) and on passenger side as well.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Apr 2005
    Queens, New York
    Quote Originally Posted by Rafster View Post
    Peace,
    Rafster
    Panasonic CQ-DF602U
    Quote Originally Posted by MatrixPC View Post
    Yeah I know, I already checked there is a relay next the the steering wheel and a fuse under the hood...The fuse is fine!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Jun 2004
    Rochester
    There could be a fuse on the rear of the head unit itself, too.
    Also there is usually some kind of reverse-polarity protection diode or fuse inside the head unit on the circuit board. If you did indeed hook up the battery + and the ground backwards, then you may have killed your deck, or maybe just fried one of these small onboard components.
    Check the wiring to see if you have swapped the battery and ground wires. If not, then your problem could be elsewhere. If so, then it might be possible to repair the deck.
    Good Luck.
    ** Denotes an "in car" post
    In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    http://rafster.dynamic-i.com/CQ-DF602U.pdf
    If you look on page 42, it tells you what to do to check the fuse...
    Peace,
    Rafster
    Mar 2005
    NY
    cheeks, i would suggest brigning your HU to turbocad or just returning it. I live in Suffolk county, and if you want to come over and let me to jiggle a few wires and play with the buttons before telling you its busted, shoot me a PM for directions
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    Apr 2005
    Queens, New York
    Hey guys thanks a lot for all of you input!!...Well here is the deal...After I finished rewiring my car for the day I called it quits cuz i couldnt figure out what was wrong with the radio. SO a couple hours later I get in my car to go to my girls house and I go to turn on my dome lights and nothing! I know that for my car some reason my dome lights and radio are tied together. I went out and checked the FUSE again! but it was not blown. SO i was really starting to get ****ed. I whipped out my multimeter and checked to fuse and guess what it was not working. Replaced the fuse and my dome lights work but I have not been home to pop my HU back it! I Will today and let you guys know!
    Thanks alot!!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Jul 2001
    Your radio's grounding itself through your antenna. Run a chassis ground to your radio and all will be good.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    As Shadow says, this is a ground problem. The ground wire in your stereo harness is not connected correctly and its trying to ground through your antenna.
    Make sure the ground wire going into the radio is properly grounded or you will continue to have problems.
  1. using a HU in the trunk
    By Nomader in forum Car Audio
    Last Post: 05-22-2006, 01:25 PM
  2. Problems on Carputer to HU
    By Grimoire in forum Car Audio
    Last Post: 05-20-2006, 05:35 PM
  3. car-pc to monsoon HU rundown *nooby* alert
    By Jamazon in forum Car Audio
    Last Post: 05-02-2006, 09:21 AM
  4. Replies: 5
    Last Post: 12-05-2005, 11:12 AM
  5. Replies: 21
    Last Post: 07-22-2005, 02:35 PM
