i have a couple more questions but figured i'd ask them here instead of making new threads.
power wise, im planning to run an inverter for the pc and wondering what would be the better alternative, i plan to have everything in the trunk. decided to make a picture since it would be easier to explain
alright, the image on the right is how i have my system currently setup (power wire wise) 4g wire into a distribution block which turns into (2) 8g wires which give power to the amps
now with an inverter in the trunk powering a pc and whatever else it needs... would the image on the left be a better option? upgrading the power wire which goes from the battery to a 0g wire and then splits into (2) 4g wires which powers the dis. block for the amps and one 4g which poweres the inverter
or would the current 4g be enough, so it would be a 4g wire from the battery to the trunk and then split into (3) 8g wires, 1 for one amp, 1 for the second amp and 1 for the inverter
and second question, what would provide better
sound quality for the money, PC -> HU -> Amp -> Speakers
or
PC -> Amp -> Speakers
cant find a definitive answer to this so figured i'd ask
and by quality for the money, i dont mean cheaper alternative, example... if setting it up for clear quality the first way would cost $400 and to get it to the same sound quality the second way it would cost $200, second choice would probably be best,
thanks again for any help on this
