You're running two sets of components for your front stage, you're running rear fill and you're using 5 amps.
There's a WHOLE lot that goes against SQ in that setup.
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
Not if it gets tuned right. It would be different if it were a simple deck. Rear fill is minor, its just to get that "behind you sound" that I like better than just a simple component set. 2 components because the mbq's lack low-mid, and the excursion speakers are good for that. 2 tweeters and full headroom. tweet up high and mid, and the woofers lower. There are things I can do to clean it up if need be, but its gonna sound good. High quality stuff
Yikes.....
I would not bridge those amps with your mids/highs. To much distortion, especially at 2ohm mono.... IF it doesn't kill your amps.
If you must use 2 sets of components give each one it's own unbridged 4 ohm channel.
I'd keep one set as midrange/high, and try to enclose another has mid bass. Ditch the second tweeter. MBQs are notoriously bright.
And yes, you need to have both RCA inputs connected.![]()
-ZtH01
"It's my belief that my big balls should be held every night"
But im gonna try it wired up that way, worste case scenerio ill just hook up the mbq's to 1 front amp and the other components to the other same amp. And ditch the other one. Im just testing it anyways. If it does sound good ill keep it and rock the extra power, if not, then im ditching my old 75x2 amp for the other components
CLARION HX-D2
to see what other people think? Why else would I ask?
other people think you need both, and still you're gonne use just one, so what does it matter what they think? right, it doesn't mean jack...
CLARION HX-D2
Well explain to me why you need both. If it just adds 2 signals together then why not just give it one signal? It shouldnt play any different
