Originally Posted by
FyreDaug
i was really ****ed off this morning and your response didnt help, sorry if I went overboard. but seriously, what says it wont sound good? If I give it one signal at 2.8v, or 2 signals at 1.4v id rather have it a little quieter and give it 3x the power for clarity. I dont need it to be 150db's, but I like to turn it up though. EDIT: keep in mind I was giving it 80wx2 before, and now I have the option to see what it would sound like if both of them got 220w
If you only use the left input that means that it would be less likely to clip would it not? Instead of adding 2 signals together to create the sound and possible have it flat peak you could use 1 higher voltage signal to have a cleaner sound. Gains will be about 25% anyways, it was at about 60-70% when I had 2 speakers off this amp running 80x2, but now I have 2 of the same amps, so I can run it 220x1 x2amps. I admit if I WERE using 1 amp for both speakers having both inputs would be crucial, but in the case of running it 1 channel, it should be fine with 1 input.
On the case of it cutting voltage half, more than half or a quarter. What would happen to the 2.8V if it were split? What would the output at both ends of the split be? 1.4?
