FEATURES
- The Premium coaxial tweeter support allows for rapid conversion of the component speaker into a coaxial system.
- Wet Powder Coating for the midrange cone
- Regardless of the wire size or type you can always connect to an MB QUART. Connection types include solder, screw-down, spade or bare wire.
- High-grade composite baskets made from MB QUART's specially formulated polyamide. The baskets utilize DIN standard mounting positions.
- The motor assembly is formed into the basket using an insert molding process.
- Balanced Temperature Technology is used throughout
- Tweeter level can be adjusted in 2dB steps up to -6dB
A light bulb is incorporated into the crossover networks to extend the life of the tweeter by protecting it against overloading.
- Tweeter with a 25 mm (1") titanium dome with a highly elastic butyl rubber surround
- Multi-purpose mounting accessories are included
- Upgrade your midbass with the Add-A-Woofer-System
