Results 1 to 10 of 13
Thread: Invert Phase by Reversing +/- Terminals?
    Low Bitrate Epon's Avatar
    Oct 2005
    Hey, I understand the concept of just simply reversing the terminal connections to invert the phase on my sub, but if I was wiring it as such:
    I would still ultimatly just plug the + into my amps - and vice versa, right? Or do I need to reverse that wiring diagram as well? Thanks.
    2004 Ford Mustang
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    if you reversed it on the voice coil connections it would cancel it out, you would be using the - cable on all + terminals so it would be the same as wiring it up normally. just change it at the amp end.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Jul 2001
    x2
    Oct 2006
    St. Louis, MO
    You do realize what reversing the phase will do to your sub right?
    Apr 2005
    UK
    nothing ?
    Type-R Mini
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Well..if the sub is designed to compress the air in a certain way (Ie, compress the air in a sealed box), then having the sub reverse phase could potentially nix part of its usefulness, because it won't be compressing the air correctly.
    Apr 2005
    UK
    but if you do everything properly then running reversed isnt going to cause any problems.
    Type-R Mini
    Oct 2006
    St. Louis, MO
    It can still cause problems...It'll push air when it's supposed to be pulling and vice versa, so when there's a bass hit, it can sound hollow or off beat.
    Oct 2005
    If the ***-end of the speaker is outside the box, then I have to invert the phase, which is exactly what I'm doing.
    2004 Ford Mustang
    Jul 2001
    Why does everybody second guess the guy without asking what he's doing?
  1. Can anybody recommend a Reversing Camera?
    By ALonDonThinG in forum General Hardware Discussion
    Last Post: 03-16-2006, 04:41 AM
  2. Reversing Camera Auto-on question?
    By sansoo24 in forum General Hardware Discussion
    Last Post: 04-26-2005, 01:21 AM
  3. Reversing camera power source?
    By Psychobiker in forum General Hardware Discussion
    Last Post: 04-21-2005, 10:12 AM
