*EDIT
Looking back at this response now its longer than I expected so I'm sorry if its a bit long winded. To sum up, if you've got a line out on your laptop, go ahead and proceed as you plan too, if not, beware the quality may not be what youre expecting. Keep reading if you want more detail
*EDIT
Alright, my first question for you would be this, does your laptop have an actual "line out" 3.5mm output, or just a headphone 3.5mm output? (Ive seen very few laptops that have anything other than a mic in and a headphone out) I only looked briefly over the link you included, so I'm not sure how much or if it was covered, but if you're going to use the 3.5mm out straight to your head unit with the RCA adaptor, you need to make sure its a "line out" and not headphones. If it is indeed a line out you're all set, and the sound will be good, including what is then run to your amp/subs. If however, it is instead a headphone output, you're going to run into problems. The reason being, the aux in on your head unit is expecting a line level, or basically unamplified signal, which it will then process and output to your speakers amp etc. If you go with the headphone output however, you have a signal thats already been amplified, and while yes its possible to just lower the volume to mimic what a line out would be providing, at least in my experience this tends to result in much lower quality. Hope this helps
LinkBack URL
About LinkBacks
