Results 1 to 6 of 6
Thread: Want to add more subs
    Oct 2006
    Right now i am running 2 12's and a 347 max amp
    http://www.crutchfield.com/S-9VqGpXJ...i=108R311A#Tab
    my amp
    and my subs
    http://www.crutchfield.com/S-9VqGpXJ...splay=Infinity
    my 6 3/4's
    What would be the easiest way to add 2 more 12's!? what would i need!?
    ThanX
    Oct 2006
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    sell the amp get one that is 800-1200 wrm @ 4 or 1 ohm and buy two more of those subs
    the elemental designs nine.1 comes to mind for an amp that can power for of those @ 1 ohm
    that amp is pretty weak for powering 2 subs. My first suggestion, before you buy more subs is to get the amps with real power (i.e. the nine.1) and see how you like the sound when those woofers are seeing 300 wrms each.
    set your gains correctly and get this amp:
    http://www.edesignaudio.com/edv2/pro...products_id=44
    it'll throw 450 wrms to those subs and should be fine...as long as the signal isn't distorted...
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Oct 2006
    Would it be as easy as switching the wires around from the old to the new amp?
    Oct 2006
    Would it be as easy as switching the wires around from the old to the new amp? also with that amp it would b fine wit 2 more 12's
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by RedbullCuban View Post
    it depends on what gauge power and ground wire you have running to the amps.
    That amp would be ok running two more subs. just make sure you have the subs wired for the correct impedance. (it's 1 ohm stable so you wont have any problem with four 4-ohm subs)
    What is your goal for adding more subs? do you want it to be louder? are you subs in a sealed box right now? or are they in a ported box?
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Replies: 10
    Last Post: 09-03-2007, 10:19 AM
  2. RE XXX Subs Amp Strapping Howto? 1Ohm?
    By Philhop in forum Car Audio
    Last Post: 08-30-2007, 02:57 PM
  3. add wire to connector and circuit diagram question
    By achca in forum General MP3Car Discussion
    Last Post: 07-29-2006, 10:39 PM
  4. New subs... Or old subs...
    By Curry in forum Car Audio
    Last Post: 06-23-2006, 07:53 AM
  5. need a usb soundcard for my subs
    By iopcool20 in forum Car Audio
    Last Post: 05-29-2006, 08:35 PM
