Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: pcmcia sound cards with line out?
    Sep 2006
    I posted a thread last week about using a 3.5mm headphone out jack on my laptop carputer as the source for my sound into my head unit and was told that this would be an amplified signal being reamplified and thus causing distortion. Thus, I went about looking for a PCMCIA sound card to use with a line out, as recommended by the posted replies on my original thread. I can't seem to find one!? The only likely one that I can find is the Sound Blaster Audigy 2 ZS but in its description EVERYWHERE (on ebay, google, etc.) it says that the Port Connectors are: 1 x Optical In, 1 x Optical Out, 1 x Speaker Dock. and in one description, it described the output as "headphone out/line out" ...I guess they described it as the same thing when it clearly isn't supposed to be. I see other threads where users are using the Sound Blaster Audigy 2 ZS pcmcia on their laptops and connecting this to their head unit for sound but if they are just connecting from the headphone out jack isn't it the same (despite the obvious extra features of the sound card) as me connecting it straight from my laptop's headphone out? Or is there a feature on the SBA 2 ZS that allows you to remove the amplification on the output? I would love to hear some feedback on this as this is my last thing on the shopping list to complete my setup. Thanks!
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    just a question, why does it need to be pcmcia? can it be usb? have you researched usb dacs too?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Sep 2006
    I have researched both PCMCIA as well as USB. However, when I search for USB sound cards on ebay, it seems there are two main types that are coming up. 1) These cheap looking flash drive looking USB devices that have a headphone out and mic in jack or 2) An actual decent looking USB sound device (like the Sound Blaster Extigy) but all of these seem to require a 12 volt source and the power supply I'm using (the Carnetix P-1900) only provides a dual output (I'm already using the 19v output for my laptop/carputer and the secondary 12v output for my touchscreen - I know you can get a third output attachment but not for another 12 v so that is irrelevant) so I would rather just get a PCMCIA card and not have to worry about trying to work another 12 volt dc regulated source into my setup any suggestions? thanks
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    Quote Originally Posted by scott_fx View Post
    i think that pci/or pcmcia is faster than USB, therefore can process audio signal faster
    Yev
    R. T. F. M
    Nov 2005
    Chicago
    Quote Originally Posted by AznArkitekt View Post
    you can always get a splitter, i would go with pcmcia for above reason, it's not hard to provide power for it, but it will be so much less hassle if you spend extra $30 bucks and go with Creative ZS
    Yev
    R. T. F. M
    Sep 2006
    Thanks for the input regarding this matter. However, my main question still goes unanswered. I don't see a line out on any of these sound cards, pcmcia or usb. I'm worried that if I run a feed from the headphone out jack of these sound cards into the input on the back of my head unit, I will be amplifying an amplified signal (amplified twice to the speakers in my car and AGAIN a third time from my HU to my amp/subs) which will distort the sound horribly. It seems that a lot of people are using the Creative ZS as a source for their sound but I see no line out on this card. Are none of these people getting a distorted sound?
    _
    Mar 2004
    Little Elm, Texas
    The ZS 2 has a headphone jack (line out)
    I will say this much, from the reviews that I have read from people, using the aux-in on head units doesn't give the cleanest sound anyways.
    Jan Bennett
    Sep 2006
    hmmmm how would you suggest I get the sound from my computer into my car speakers/amp? I couldn't figure out any other way other than to go with the aux in (or at least this seemed to be the easiest way)
    Dec 2004
    Los Angeles Ca
    go directly from the soundcard into the amp
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Sep 2006
    my car doesn't have a stock amp for the tweeters and mids inside the car, the only amp I'm running is a 500/1 JL Audio for my subs in the back so how do I get sound from my sound card to the speakers inside my car? :-/
  1. Dual Sound Cards?
    By HummDinger in forum Hardware Development
    Last Post: 04-11-2007, 06:53 PM
  2. Replies: 8
    Last Post: 11-05-2004, 11:30 AM
  3. Replies: 1
    Last Post: 08-12-2004, 08:11 PM
  4. need recommendation on laptop sound card (pcmcia)
    By Fiddler in forum General Hardware Discussion
    Last Post: 03-14-2000, 07:05 PM
  5. Sound cards....
    By mp3stealth in forum General Hardware Discussion
    Last Post: 03-10-2000, 03:32 PM
