Results 1 to 8 of 8
Thread: headless problem
    Oct 2006
    headless problem
    Hi, i'm trying to run my car speakers head-unit-less directly from the PC to the AMP. However, no matter which mode I have the computer speaker setup running on (ie: stereo 2 channel, 6 channel) I cannot get signal on one side of the speakers. I'm using a 1/8 to RCA cable, and only the white jack works. The same thing happens when I use a 1/8 to RCA adapter and regular RCA cables. Also, the volume on that one speaker is very low, and sounds very crappy. I'm running 6channel realtek onboard audio (I know, it sucks... but it'll have to do for now), 2 two-channel Rockford Fosgate 301s amplifiers, a pair of cdt speakers (they both work, and are wired correctly.) and an Alpine Type-r and another amp. amp (but i'll worry about that later)
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    hey, are you sure you picked up a stereo adapter, not a mono? They sell mono 1/8 inch to rca adapters with two rca's, so you may have picked that up by accident... worth a check
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Oct 2006
    yah, their stereo. On top of that, the direct 1/8 to RCA stereo cable doesnt work. I'm thinking its my amps.
    Oct 2006
    it isnt the amp. both channels work, its just that the red RCA cable doesnt work for some reason. I know the cables are good, i used multiple cables and 1/8 to rca converters. They are stereo. Maybe sound card is bad? I'll probably get a new one anyway..
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    how do you know that the cable is good? do you have a discman or mp3 player? hook that up to the cable and see if you're getting the same results. if you are then it's your cable. if it solves your problem then it's your soundcard.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Oct 2006
    its my soundcard jack. I tried using the soundcard jack on the front of the case, and its good! time for a new soundcard, any suggestions?
    Nov 2004
    NY
    silverstone EB01
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by d31usion View Post
    what's your budget?
    Quote Originally Posted by Dennis5587 View Post
    silverstone EB01
    good suggestion. do you have one? how do you like it?
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-30-2006, 11:09 PM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 07:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 10:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-15-2005, 11:10 PM
