Results 1 to 3 of 3
Thread: Faulty amp or wrong wiring?
    Low Bitrate dima237's Avatar
    Aug 2006
    Well, my whole system is ready to go as all part are now in. I was just about to start with wiring audio first and decided to test a new amp that I just got off ebay (MTX 404). I powered everyting (power to battery directly for testing, remote to ACC and stock speakers through harness). Front speakers sound just fine, but rear ones a just kind of a quite buzzing noise, I can hear that it's the audio, but it's just quite and buzzing. I thought maybe it's my wiring to the harness, but when I connect the rear speakers to front output, it's fine. So I'm concluding that it's the rear outputs of the amp.
    Is that right? Is it possible to have 2 out of 4 channels be fried? If that's the case, that would really suck as I was excited to finish everything on the weekend.
    Mar 2006
    Colorado, but Canadian!
    Yes it is possible for 2 of your channels to go. If you really want to finish it fast, then get some splitters so that you get 2 channels out of the amp to the 4 speakers. dont do that for long though. You need an amp.
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2006
    Thanks for quick reply. This blows. As they say, whatever can go wrong, will.
  1. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 09-05-2012, 11:43 AM
  2. Amp Shuts Off
    By ElementXofXMusi in forum Car Audio
    Last Post: 07-18-2006, 08:34 PM
  3. ITX sp1300-> AMP wrong resistance?!?
    By Power_nisse in forum Car Audio
    Last Post: 05-13-2006, 04:23 PM
  4. Replies: 26
    Last Post: 12-20-2005, 07:23 PM
  5. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
