you'll have to wire up front and rear of each side, that way you'll play at 2 ohm. BUT, in that case the dampingfactor of your amp will draw back, and soundquality will be drawn back also. so what's the power output of your amp at 2 Ohm? it should be around 120watts RMS per channel, for you to get full advantage of the speakers.
LinkBack URL
About LinkBacks
