Results 11 to 20 of 22
Thread: Converting an Audio Signal to a Voltage
  1. #11
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    No, I tried and failed. A guy I know who is a real electronics guy is working on it now.
  2. #12
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by ukchris View Post
    You can try something called a VOX (or voice activated switch). I have a schematic at home, it just needs a little modification to make it work as you suggest. Can be built for much less than the David Navone piece. I just haven't had time to sit down, build, and test the thing, but in theory, it should work.
    Michael
  3. #13
    Nov 2003
    Massachusetts
    I have a couple of schematics for VOX circuits, even tried soldering one up but it didn't work for me. I don't know enough about the electronics to determine why. I'm not bad at sticking the bits together if someone can tell me what bits work, the ones in the circuit I followed didn't.
    Chris.
  4. #14
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Chris.
    What happened/what didn't work about it? DId you modify the circuit at all?
    Michael
  5. #15
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    PAC Audio makes a TR4 or a TR7 that MIGHT work. Maybe your audio signal voltage level might be too low though. Have you measured what the output AC voltage is of your audio signal with a multimeter? What is the minimum voltage level your VOX will work at?
  6. #16
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    If you scroll to the bottom of this page: http://www.doctronics.co.uk/4016.htm
    It gives a possible application for the 4016 IC, but the first half of the circuit coverts audio into a voltage. Might be useful, and you can probably make it for less than a $2-3 if you have an electronics store nearby.
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
  7. #17
    Nov 2003
    Massachusetts
    My problem is I have none of thses bits so I end up spending $20-30 at Digikey to get going. If any of you are willing to make me such a circuit I'd be happy to make it worth your while.
  8. #18
    Jun 2005
    Oakland, CA
    Sorry, I don't have time (I'm at my last year of mechanical engineering at UC Berkeley! woot!), but I can help out with schematics and adding features if you like.
    ...it never ends
  9. #19
    Aug 2008
    Newbie, here.
    I want bluetooth and gps from a carputer. I've got an old mac laptop sitting around; should work fine.
    I want to use my headunit; the best way to integrate the sound into the headunit, in my opinion, is to use some sort of auto mute to break the signal from the speaker output on the HU. This should work for all carputer output - navigation and bluetooth phone calls.
    I've found some standalone auto mute relays in the UK; this seems like the easiest way to do this and integrate with a factory HU. Does anyone know of any US distributor for a standalone auto mute sensor that's installed between the output of the HU and the speakers?
    This seems to be what you are talking about in this thread.
    Thanks.
  10. #20
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    best way to do what you're describing involves a mixer and maybe a mute circuit
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. timeouts and bluetooth audio randomness
    By numbers in forum PhoneControl
    Last Post: 01-09-2006, 03:44 PM
  2. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 03:06 PM
  3. Replies: 1
    Last Post: 06-05-2005, 12:39 AM
  4. What Gauge wires do I use?
    By Showmehow in forum Newbie
    Last Post: 07-25-2004, 10:41 AM
  5. Where should I put the audio signal to?
    By dudah85 in forum General Hardware Discussion
    Last Post: 04-22-2001, 05:43 PM
