Results 1 to 3 of 3
Thread: Piping audio to DSP via S/PDIF
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Hi,
    I have a Roadie usb soundcard which is connected via a s/pdif cable (optical) to a DSP. I have verified that the Roadie is producing sound (by listening to it via the headphones) and have checked that the DSP produces sound -- by running a speaker test from it. However, when I try to play sound from the roadie software, mp3s, and/or dvd's I am getting no sound. The DSP says it can decode PCM, DTS, DD, and Pro-logic. However, no matter what I play -- the DSP doesn't register seeing any of the above (it has pretty lights that illuminate what it's decoding).
    So, I am requesting help in figuring out how to get the sounds from my computer to play out of my DSP. Hopefully, this won't require going analog to accomplish it.
    I would really appreciate any hints.
    Nasa
    btw: I did do the search thing.... Maybe I suck at it???
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    did you update your drivers?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Aug 2006
    PA
    Thanks for the reply,
    which drivers are you refering too? The AC3Filter files (which I have installed the latest of)?
    Nasa
  1. Replies: 56
    Last Post: 06-09-2006, 05:43 AM
  2. Virtual Audio Cable
    By tj!2k4 in forum Software & Software Development
    Last Post: 07-22-2005, 03:58 PM
  3. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  4. Replies: 1
    Last Post: 06-05-2005, 01:39 AM
  5. Special audio preamp circuit
    By claylong in forum General Hardware Discussion
    Last Post: 01-14-2003, 06:19 PM
