Results 1 to 10 of 10
Thread: creative usb soundblaster
    Feb 2006
    Virginia Beach, Va
    I think i have everything hooked up properly. I have the black and red rca cables coming from the headunit goin into the headphone jack on my soundcard. The thing is that the sound is very low. I put the volume way up in windows and on the soundcard itself. I Also kinda hear the static, but I guess because the audio isnt loud enough.
    Any help would be appreciated
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Well give us a little more information...
    Do you have a custom sound system? Do other inputs output sound properly..etc....
    How are you converting the headphone lead into an RCA line? Is it a puchased splitter or did you create it yourself.
    If you put another input to the headphone line (say an mp3 player or cd player), is it just as low?
    Basically break down your system step by step until you find the exact part causing the problem and take it from there.
    Brown 2010
    Feb 2006
    Virginia Beach, Va
    Quote Originally Posted by Sidewalksalvage View Post
    Ok i dont have any sound system.
    I use a coupler to connect one end to the black & red rca's coming from the headunit and connect the rca to headphone cables to the soundcard.
    I figured it was the soundcard, but i guess thats something I'll have to figure out
    Jun 2004
    Rochester
    What head unit do you have?
    What connection are you plugging into at the head unit? You said "rca's". Can you be more specific?
    ** Denotes an "in car" post
    In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    id do that first
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2006
    NJ/RI
    Quote Originally Posted by walky_talky20 View Post
    Just a side note, an RCA type plug is the same type of plug that is used when connecting many game consoles/vcr's/low end dvd (the three plug design white red yellow)
    So that is pretty specific connection wise (unless of course that isnt the plug you are using but im betting it is) As for a head unit model, its something to look into, someone may know if there is an odd compatibility issue or setting thats best for a carpc
    Brown 2010
    Variable Bitrate miwise's Avatar
    Sep 2006
    The external volume control on that soundcard does nothing for the rca jack. This is only headphone volume. The volume of the gold (white and red) jacks on the back depend on one thing, the volume controlled by the mixer in windows. Other than that, you should check your head unit. I have a kenwood that allows adjustment of each input so that you can level out all of the volumes for various sources. check and see if your headunit has that. Other than that, make sure you have the latest soundblaster drivers installed. I remember something about this model and needing at least service pack one of windows xp as well. I used to have problems with the optical output on mine. I believe it is bound to be something simple, though, like the headunit input sensitivity being turned down. Read your owner's manual for the headunit and see how to turn it up.
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
    Jun 2004
    Rochester
    I wanted to make sure that canibusfan was indeed plugging into the "AUX" input. RCA's are used for both input and output on headunits (more often output actually). I have seen people mistake a PreOut for an AUX input before. If the sound is "very low" as described, there is a chance it could be caused by backfeeding a signal into a preout.
    Peace.
    Mar 2006
    NJ/RI
    Peace.
    Thats a VERY good point actually... Didnt think of that....!
    Sounds kinda like stating the obvious but its very possible.
    Brown 2010
    Feb 2006
    Virginia Beach, Va
    nm i fixed the problem.....I just needed to turn the volume up on the headunit....lol
    sorry guys
  1. Ultimate USB, Firewire, External Soundcard List
    By durwood in forum Car Audio FAQ
    Last Post: 12-30-2009, 06:15 PM
  2. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  3. USB Roundup
    By JPuma in forum General Hardware Discussion
    Last Post: 09-17-2006, 05:47 PM
  4. Possible WinLIRC + (USB Soundblaster MP3) issue?
    By DMX in forum Input Devices
    Last Post: 11-27-2004, 02:20 AM
  5. Problems with USB SoundBlaster
    By Vadim in forum General Hardware Discussion
    Last Post: 06-02-2004, 12:01 AM
