Results 1 to 10 of 16
Thread: Not Engine Noise but static
    May 2006
    I've had my pc in my car about 6 months now. I have a HP slim line pc being powered with an inverter I just added a kicker 3504 4ch amp and a kicker 7501 sub amp Im using the onboard sound card right now using 3.5 mm to rca adapters to the amps using front rear and sub outputs. I am not encountering any engine noise or whine but I'm getting a low level static through all speakers. when i remove rcas from amps there is no noise its only while playing music from computer. Any ideas??
    Nov 2005
    CT
    Chances are your soundcard isn't outputing a high enough voltage for your amps, forcing you to set the gains on the amp to high. But just in case...
    If you unplug the RCA's from the soundcard is there still noise?
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    REBUILDING!!
    Oct 2006
    I have another thing to check! This happens a lot with power inverters. Where did you get your power from? If you are using the cigared lighter jack then the power may just be "dirty"! I've seen this quite a bit. Try moving to a more reliable area. I suggest you tag power at an Ignition or Accessory wire in the ignition column (please do not use fuse splices at the fuse box). And get a fresh ground in the kick panel. This is always the best route for getting power to major, sensitive components. I almost guarantee this will solve the issue. If not then try getting a higher quality inverter with better filters, but not until you move your power and ground!
    Nov 2005
    CT
    ^^^^ Although this is true and could help the issue, the signal level output of a standard sound car is about 0.1-1v. So even with a cleaner power supply to the computer your still going to need some kind of pre-amp so as to not max out the gains on the amp. You can check the voltage output of the soundcard with a multimeter.
    May 2006
    I'll turn my inverter off and try using regular ac power from a outside source and see if the noise is still there. If it is what external sound card could you suggest? My pc has 1 free pci but it is so small that I can't install anything internal
    Low Bitrate Epon's Avatar
    Oct 2005
    Any suggestions on the preamp?
    2004 Ford Mustang
    Aug 2004
    I believe there is a thread on this topic.. no wait theres two.. I think you should search.
    REBUILDING!!
    May 2006
    turned out one of my ss component woofers were blown and causing the static replaced it today and sounds awesome
    Aug 2004
    the hiss was coming purely from the subwoofer?
    REBUILDING!!
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 08:38 PM
  2. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 02:36 AM
  3. Terrible static noise on SP13000 (internal audio)
    By BlackStealth in forum Newbie
    Last Post: 05-15-2006, 01:44 PM
  4. Noise (from engine and other sources) HELP!!!
    By sstylos in forum Car Audio
    Last Post: 09-20-2005, 12:41 PM
  5. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 10:31 AM
