This is caused by the soundcard/pc powering down while the amp remains powered for a fracion of a second longer (internal caps?).
You should power your amp down when you cut ignition, so it's really off by the time the pc hibernates (you can still power it on when the pc boots, using a relay cirquit).
Good luck!
LinkBack URL
About LinkBacks
