Results 1 to 10 of 15
Thread: rca wire too long?
    Newbie cheever's Avatar
    Apr 2006
    charlotte, nc (close to)
    rca wire too long?
    Here's what I got hooked up at the moment:
    A 4channel amp powering the regular car speakers and a 2ch amp powering my subs. I have an RCA cable running from my center console to my 4ch (I split th signal just before the 4ch amp to feed my sub amp). My RCA cable is ~20 ft long and all I have pushing music is my IPOD via a 1/8" to RCA convertor. What Im running into is that after a while the front deck will totally go out, until I turn up the volume real fast, then everything kicks back in for a little while longer. This problem goes way once I plug up power with a cigarette lighter adapter. That's fine but apparently it's not grounded well enough because I can hear the noise that matches the engine rpm. I hooked up the ipod to the 4 ch amp directly with a really short RCA, everything sounded great. Is there any chance there is a signal booster for an RCA cable that isn't a full blown amp? It seems to me that the ipod does not push enough power through it's headphone jack to give me what I need.
    Perhaps there is a better method than what I have...cheaply..
    Once again I truly appreciate anyone who takes the time to help me out on this.
    Jul 2001
    What you're describing is a line driver. A good one's going to run about $65.
    Oct 2006
    Yup, what Shadow said!
    Newbie technostar's Avatar
    Sep 2006
    i got one of these CLARION EQS746 Equalizer. it has two inputs, aux and main, and you may select each one by pressing a button.
    broom-broom-pc
    m-atx:amd2600xp:512mb:40gb:m2-atx:roadrunner:lsxvoid
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by technostar View Post
    and what the hell does this have to do with the problem discribed by the topic starter?
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Mar 2006
    Colorado, but Canadian!
    i think you could use a preamp as well. You can build one like the picture for like $5 and it will be fine for the audio that the iPod spits out. If you need audiophile type music, then you need to spend some money like shadow said.
    Just replace the "mic in" with "ipod in"
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2006
    Quote Originally Posted by IC-C30 View Post
    he's asking for a signal booster for rca. this preamp i was referring to may serve as well like a line driver. was i out of topic here?
    broom-broom-pc
    Jun 2006
    Abele, Belgium
    meh, why buy an EQ if you just need a line-convertor? if you wanna use an EQ, you'll have to spend money for a good one, and since he's just looking for a line-convertor, that seems a little over the top in my opinion.
    CLARION HX-D2
    Jul 2001
    Hey all you rockheads, a preamp IS a line driver.
    Mar 2006
    I never use word like that because I know what I want it to do, so I don't know what it is called. I call pre-amps/linedrivers: boosters. I know, makes no sense, but I know what I want.
  1. extending my TS's ac adapter wire
    By skadoo323 in forum Power Supplies
    Last Post: 02-02-2006, 01:09 PM
  2. Long RCA or Line-Out?
    By jimothy in forum General Hardware Discussion
    Last Post: 04-29-2005, 02:39 PM
  3. Opus 90W power supply wire, 8 ga wire?
    By muldrick in forum Power Supplies
    Last Post: 08-27-2004, 11:27 PM
  4. Replies: 11
    Last Post: 03-09-2004, 10:59 AM
  5. RCA to Speaker wire?
    By greenglo in forum General Hardware Discussion
    Last Post: 02-16-2004, 03:20 PM
