Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: 1.2 Farad Capacitor.. Need Help!
    Newbie Yacob's Avatar
    Nov 2006
    Connecticut
    Question 1.2 Farad Capacitor.. Need Help!
    I recently bought a single 10" Power Acoustik sub with 1800 watt max. I am feeding 980 watts to it with a Power Acoustik amp. I also have 4 guage wire. Everytime my sub hits a hard note my lights and other electrical components in my car go dim. So I read up on some capacitors and I ended up buying a 1.2 Farad Voodoo Rack Mount Capacitor. I wired it up and yet my lights still go dim. I am not sure if it is even working.. I charged the cap and everything and I'm almost positive it is wirred correctly. I need to know what else there is I need to do or what I missed.
    Nov 2005
    CT
    1. Max wattage is a useless #. Look at RMS.
    2. You should have read about how caps are not a cure for dimming lights. You need to upgrade the Big 3. Do a search for "Big 3" on this or any car audio forum. Or even
    Nov 2006
    Connecticut
    Thanks.. I didn't even know about the "big 3". I will go out and buy some larger wire and try it out. Thanks for the idea.
    Any more advice?
    Jul 2001
    Don't use a cap!
    _
    Mar 2004
    Little Elm, Texas
    and do the big 3, all the advice you need right now.
    Jan Bennett
    Nov 2006
    Connecticut
    Is it bad to use a cap? What are the Pro's and Con's?
    _
    Mar 2004
    Little Elm, Texas
    this has been covered in great detail on this forum, many many times.
    Jan Bennett
    Apr 2005
    Queens, New York
    IS it bad to use a cap NO but pointless!.....I think that a cap really doenst do much unless you get like a 10 15 farad cap
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Nov 2005
    CT
    It can be bad when your adding another electrical component to an already overdrawn electrical system. Like red said its been discussed countless numbers of times on many forums.
    Jul 2001
    It's still stupid. A 10 or 15 farad cap would cost easily two times what a good solid battery would cost with a fraction of the performance.
    PS 1000th post
  1. 1.2 Farad Voodoo Cap.. NEED HELP!
    By Yacob in forum Power Supplies
    Last Post: 11-05-2006, 05:33 PM
  2. Bluetooth 1.1 or 1.2? am I being fooled
    By tryme in forum Wireless Communications
    Last Post: 02-09-2006, 11:58 AM
  3. CF 1.4 skin for CF 1.2
    By superbowl in forum CF Skins
    Last Post: 08-08-2005, 05:19 AM
  4. Using a high farad cap to survive engine crank
    By lakorai in forum Power Supplies
    Last Post: 03-28-2005, 10:47 AM
  5. EBAY: 1.2 Farad Cap
    By dchaug in forum Classified Archive
    Last Post: 05-16-2003, 09:51 PM
