chances are the sound card isn't putting a signal out of the analog and digital outputs at the same time
does your amp have a 2/4 channel switch to allow the rear inputs to feed off of the fronts signal? If so, unplug the rear rcas and flip the switch and see if you notice a difference.
Have you adjusted crossovers for this amp at all? Have you gone into the settings on the sound card to tell it what outputs to use?
LinkBack URL
About LinkBacks
