Results 1 to 10 of 15
Thread: connecting home stereo to car speakers....
    Nov 2006
    ok so i have this sick *** home sterio with external speakers.... i have alredy molded the small house stereo into the car, and i have to connect the +- left and the +- right of all 4 car speakers to only 2 connections of the car.. what do i do....
    i think it similar to connecting your computer to the car.
    please help me out... ill post pics when im done.
    _
    Mar 2004
    Little Elm, Texas
    a home stereo with external spakers? as opposed to....??
    by 'molded the small house stereo into the car' what do you mean? you have molded the reciever and amplifier into the trunk of the car? how are you powering this? I hope not an inverter....
    connecting 4 speakers to only 2 inputs in the car? in the car where? the stock radio? the home reciever you've molded into the car?
    I cannot help you as I cannot understand your post at all...please try and be a little more descriptive.
    Jan Bennett
    Nov 2006
    Quote Originally Posted by RedGTiVR6 View Post
    well, i took some llike clock raido thing and loved the way it worked in the house. i took out my car stereo and put it in it. no i gota figure out how to power a home stereo and how to connect the car speakers to it.
    Nov 2005
    CT
    I'll look past the why and try to help you.
    So your trying to connect a home radio to your car. Things you need to know.
    1. What it needs for power. It will usually say it on the back near where the plug connects.
    2. What the rms and ohm rating of the speakers that are supposed to be connected to it are to insure that it will work well with you car speakers.
    And now I am going to ask it... Why??? Its going to be difficult to implement and probably sound crappy.
    Nov 2006
    here is why....
    http://www.ihomeaudio.com/products.a...1&dept_id=1003
    i want to put that in my car....
    the pop out ipod thing would be cool...
    i opened it up and took out the speakers. now i wana connect my car speakers where the orignal speakers were and power it.
    any tips or what wires?
    Nov 2005
    CT
    Can you answer any of my questions above? You do realize this will probably not go smoothly...
    Nov 2006
    well its a regular house thing... im thinking 110..
    i opened it up and inside where the power thing is it says 94v-0
    so im guessing it gona need atleast 94 vaults...
    i was thinking of a power inverter but i heard its not the best way.
    as fot the speakers in the car they are stock
    the speakers in the system are small and dont say ohm's or rms or anyhting on them. if u would like i can take pics of what i need to do,
    _
    Mar 2004
    Little Elm, Texas
    vaults? do you mean volts?
    using an inverter on something like this is just plain nuts.
    I would NOT recommend doing this, not at all. Cut your losses and find another way to make this happen. Use a dock.
    Jan Bennett
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK. I'll throw my tuppence worth into this.
    Again I'll ignore the why.
    1 Sometimes things like this have a DC input sometimes they don't. Have a good look around and see if there is any form of socket that indicates it might have a DC connection.
    2. If it has a hadphone out, then you could hook it up to a HU that has AUX in, much like we do with our Car PCs
    3. This seems to be a real edneck thing to do. Where you from?
    Jan 2006
    okay, i'll be the a-hole here. This is stupid and very juvenile thinking... Don't tear apart a perfectly good unit, leave that in the home. Some home equipment may work in cars, that doesn't work.
    Or what you can do is sell that unit and invest your money into a good car stereo w/ an Ipod connection. Or you can go even further and purchase a CarPC to work in the vehicle. But again, i'm just trying to tell you that i've seen people do things like this before and it's not worth it whatsoever.
    Btw. If you must, power inverter into the unit, take the audio output and hopefully your radio has an AuxInput and connect the audio into that. Otherwise, buy an amplifier, connect the audio output from the unit into the amp, from the amp to the speakers. I'm assuming you're trying to use as little money as possible? My recommendation, save your money up until you can get a half decent setup. That's what i recommend to MANY people alike.
  1. Home speakers in the car
    By impulsenine in forum Car Audio
    Last Post: 11-23-2006, 03:57 AM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  3. Help with 4 speaker stereo in 2 speaker car
    By phillip hatton in forum Car Audio
    Last Post: 05-22-2006, 01:27 PM
  4. car amp with default speakers?
    By 273BeLow in forum Car Audio
    Last Post: 03-30-2005, 12:53 AM
  5. Car Stereo + Car-puter = Brown-outs???
    By Focadillac in forum Power Supplies
    Last Post: 11-10-2004, 11:14 PM
