About the cap. Can I use this resistor http://www.radioshack.com/product/in...entPage=search? its 10Watts instead of 5 to charge the cap? Also when you say charge it...................up to where should I charge it? When the LED on the tsunami says 11V or 12V? also how fast do I connect it to terminal? in a matter of seconds or can I take my time screwing in ring terminal? Also will I get shocked as I turn the allen wrench with battery still connected? Also does the car have to be one as I charge it?
Here is how I plan on charging and correct me if I do this wrong.
1. Unplug power wire from amp
2. Put the power wire to one end of resistor and touch the other end on the + side of the cap.
3. Watch LED as it charges and disconnect (let me know when i should disconnect)
4. Remove resistor in between and screw terminal into + cap side and begin to use.
LinkBack URL
About LinkBacks
Anywho thanks for the replies guys
