i'm going to go ahead and qualify megalorese15"'s statement by saying that you don't NEED a cap, but it IS beneficial to have one IF your alternator can keep up with your amp. IF your alternator can handle the overhead for charging the cap AND supplying your amp, then you will be rewarded with a higher, cleaner voltage at your amp which means your amp isn't working as hard nor drawing as much current to make
music.
IF your alternator can NOT supply ample current for your amp, then a capacitor will do you NO good.
Nothing against anybody personally but it just ****es me straight off to hell when people just roundly reject an idea with absolutely zero support or qualification for their own ideas.
