Results 1 to 10 of 15
Thread: alt whine that I dont think was there before, with amps off even!
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    Its kind of annoying too, im 95% sure when I put the system in I had 0 alt whine, 2.5% sure it was very minor and 2.5% sure it was there. But it seems to me that its new because even with the amps off (remoted by m2atx) when I crank my car I can hear it whine as it cranks up. Seems to really only make noise below 3000rpm too. I checked all connections and they are all good, could it be some other source of interference?
    I have a line driver coming from DURWOOD which hopefully shows up soon, that has different selectors to possibly reduce ground loops noise, where do I start?
    (note) this seems to have happened after one of my 5.25" excursions blew on me, and it also seems more dominant on the driver side of the car (ie if I sit in the pass side its not as loud as it is in the driver sear)
    Maybe I missed a connection coming loose or something somewhere, but would that even cause alt whine? Its clearly rpm related
    edit: and before you even mention the stick: Induced noise/Ground loop trouble shooting guide. im there still reading through it, Id like some suggestions tho
    edit2: also, my motherboard doesnt have any grounds connected to it (from the screw holes) are they a common 12V ground? Could I add a string of wire to the mobo to the chassis of my car with my m2atx?
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    It whines when the amplifiers are not on at all? That might be something with your car. Maybe a bad bearing in your altenator or the belt is slipping. You shouldn't have any alternator whine through you speakers if the amp is off. Otherwise check to make sure none of you speaker wires are touching ground. That is all I can recommend.
    Jan 2005
    Saskatoon, SK
    still no luck, and the gf had to take the car all day. Wont be able to figure it out till tomorrow >_<
    Sep 2006
    When you get it back, try running it without the RCAs plugged into the amp. If it still does it then its associated with the amp or speakers. Also if the Soundcard is PCI and if its tweaked a little it can cause engine whine.
    Jan 2005
    Saskatoon, SK
    rca's unplugged still noise, amps off, still noise.... WHAT THE HELL. I havent disconnected + yet
    Sep 2006
    damn I am clueless. Maybe you need an engine tuneup. Spark plugs, new wires. I am just throwing that out there. Unless you check each speaker wire with a multimeter to ground and see if one wire is touching ground in your car I really don't know.
    Here is another troubleshooting guide.
    https://myeporia.eporia.com/resource...ote%201002.pdf
    Jan 2005
    Saskatoon, SK
    Engine is ok, but why would that cause noise from the speakers? I have a tweeter mounted up by the windshield and I put my ear to it, it is distinctly coming from speaker. Even if it were a slipping belt, that wouldnt do speaker noise...
    bad amp?
    Sep 2005
    Let understand this, you get alternator whine with the amplifiers receiving no remote turn on?
    IF this is the case it is either speaker wire grounding (chaffed cable) or inductance.
    Disconnect your speakers wires from the speakers (at the drivers).
    Still got noise?
    This is a *&^$$ of a problem. Basically your drivers are picking up RF through the driver coil. Options?
    1\Move the drivers (possible but not feasible)
    2\Shield the driver. The name of this metal that is used in computer cases to shield drivers is MuMetal. Don't bother trying to buy thi$$$$$$$$$. Salvage a reduntant section from an old computer. This is the best option, other choice is to aluminium foil and ground it around the driver coils.
    3\Try exchanging drivers, last resort, some are less susceptible than others.
    No noise
    Great
    Are you using passive crossovers?
    If so these can pick up noise through their coils.
    Reconnect the speaker wires, and disconnect the speaker wires from the amplifier side of the passive crossovers.
    Noise?
    This ones easier to deal with.
    1\ move the (offending) passive crossover. 1 or 2" is usually enough, simply extend the wires for movement and rinse and repeat.
    No noise
    If the noise is coming from all speakers it is most likely the amplifiers.
    Are your amplifier cases grounded?
    This can help amplifier case to shield RF.
    Last one is unusual and possibly only feasible with the amplifier running.
    Empty RCA input is acting as an antenna.
    Mute all empty RCA inputs as "good standard practise"
    Hopefully you know how to make mute plugs.
    Jan 2005
    Saskatoon, SK
    ill look into this more, ill check to see if the amp is leaking power through the speakers, if I pull the + off, then the noise stops it has to be some sort of power issue, if its still there, ill disconnect the speaker wires at amp, and check, if not then uhh... I guess resolder the connections on the speaker, I can only hear it from the tweeters, mostly the left, I only have 1 component set hooked up. Passive crossovers as in an mbquart crossover yes, (pretty sure thats passive, no power going to it, just speakers wires in and out, crossed over internally)
    Jan 2005
    Saskatoon, SK
    hah, know what it was? My 4awg wire going from battery in trunk to hood area was too close to my in-active crossover. This set is disconnected, and I also know why it wasnt there before too, its because when I disconneted the blown 5.25" woofer I must have moved the wires a little bit and the power wire was too close to the crossover. Thats it, move 4awg to go around it and problem solved, thanks guys
  1. Alt whine of a different type?
    By Philly#1 Lex in forum Car Audio
    Last Post: 10-25-2006, 01:43 PM
  2. Replies: 12
    Last Post: 07-08-2006, 11:28 PM
  3. Okay...once again...ALT WHINE YAY....
    By Sidewalksalvage in forum Car Audio
    Last Post: 04-28-2006, 12:23 PM
  4. Hardest alt. whine question ever!
    By vettejock99 in forum Car Audio
    Last Post: 04-24-2006, 01:00 AM
  5. Strange alt whine when more than 2 channels (LONG)
    Last Post: 02-26-2006, 12:38 PM
