Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: MP3 Playback Problem: Audio stutters / skips / choppy
  1. #11
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Is your problem with music or DVD's or everything audio related? Mine skips/choppy during DVD playback only because of the bandwidth issue on USB. I am using a soundblaster 24bit live USB. The resource usage is just too high a demand.
  2. #12
    Newbie Autonator's Avatar
    Oct 2006
    Houston, TX
    510SX, The High def audio driver that came in the realtek driver install pak, is a microsoft driver.. or at least the name as it shows up in the device manager is "Microsoft High Definition audio blah blah dirver".
    Do you have more ino on your sound drivers? At 900mhz, you should be able to play MP3's with no problems, but you cant run Vizualizations.. that would be very risky. I do not know what otehr apps and processes are on your system, but i would suggest looking for the latest drivers for your onboard audio hardware and try that first.
    Chrysler Sebring 2004 Conv Limited Ed.
    Commell LV-677.
    Voom PC case.
    M2 ATX PS.
    1.8Ghz Intel Core Duo.
    1GB PNY RAM.
    Dynamix 816 (8", Wide, TS).
    80GB out of a broken laptop.
    WiFi Atheros (HP) out of a broken laptop.
    OS: Win XP MCE.
  3. #13
    Oct 2006
    Houston, TX
    Quote Originally Posted by durwood View Post
    I never tried a DVD on my system except when it was on the test bench indoors.. Your situation seems more of a bottleneck issue. USB2.0 does have enough bandwdth to play a DVD.. what is your proc? i believe its a 1ghz? if you have one of those embedded procs by VIA, then i think that would be not enough to process DVD via USB due to several facts. I had a experience with a VIA 1ghz on a desktop PC at a friend of mine., and it did very hard work when we tried to install PowerDVD and run a DVD. Remeber that the DVD player software itself takes a lot of resources. You might get better performance if you hook teh DVD up via the IDE controller or the Serial ATA if you have one on your mobo. That would free teh system of going through the USB hardware layer and conversion.
    do you have more details on your setup?
    Commell LV-677.
    Voom PC case.
    M2 ATX PS.
    1GB PNY RAM.
    OS: Win XP MCE.
  4. #14
    Sep 2006
    Ya you can check out my worklog by clicking on the Mazdaspeed6. I changed 2 things this year over my previous install. In my previous install I was running an IDE DVD drive directly connected to the IDE bus and I had a PCI soundcard. Now I have a USB DVD drive and a USB soundcard. The soundcard itself while playing MP3's uses about 20-40% CPU. I have two optinos at this point, try out a PCI USB add-on card, or revert back to my PCI soundcard. It shouldn't be the DVD drive because I know plenty of people are using them on a the mini-itx boards. I watch DVD's very rarely, so its not real high on my list of priorities but sooner or later I need to fix it.
  5. #15
    Jun 2005
    Quote Originally Posted by Autonator View Post
    I don't run vizualization. My laptop has winxp sp1, froodoplayer, freedrive, and necessary microsoft component to run the program, that's about it. my CPU usage is around 20% and about 130M of ram used (I have 384M).
    I am using audigy NX2 USB sound card. I downloaded the lastest driver and installed yesterday, it seemed got better. I am still hearing the imperfect sound once in awhile. The sound is like playing black plastic album (the static sound). I updated all the firmware and drivers last year, but I will look into the Dell website again tonight.
  6. #16
    Sep 2006
    How are you suppling power to the Audigy NX? Maybe the external power isn't regulated enough for the NX.
  7. #17
    Jun 2005
    Yes, I have a 12V to 5V 6A power supply. This box hanles all my 5V devices such as my USB hub, NX and my external DVD. These devices added up, takes about 5A.
    How do you check if it's regulated enough?
  1. Audio muted problem
    By Tsleon in forum RR Bug Tracker
    Last Post: 10-20-2006, 06:09 PM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. audio problem
    By tiburonputer in forum General Hardware Discussion
    Last Post: 08-11-2005, 04:58 PM
  4. VIA M10000 on-board audio input problem
    By rjoek in forum Car Audio
    Last Post: 01-26-2005, 06:34 PM
  5. Connect hand held MP3 player to car audio system?
    By jasonwood in forum General Hardware Discussion
    Last Post: 10-31-2001, 12:30 AM
