Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: Need wiring help for 2005 Grand Prix.
  1. #11
    Nov 2006
    I'll have to take the deck out again and see if I can get the test light in the back of the stereo connectors while it's hooked up.
    I'm keeping the factory system in the car for now, it sounds pretty good as is, I just wanted to add an amp and a sub just to get a little more of a kick then what the stock system can give.
    turbocad6, the retained accessory power circiut that you're talking about, would I still be able to run my turn on lead to my amp from that asuming I can find the wire?
    If that doesn't pan out, I'll check the hvac, and the acc wire under the dash.
  2. #12
    Oct 2004
    NY
    the rap circiut is when you park & turn the key off, the radio & windows & stuff continue to be powered for up to 20 min unless you open a door.... the rap circuit can be tapped at the stock radio, but when you remove the radio it no longer functions...
    I would highly recommend retaining the rap circiut by adding the onstar module if the radio is removed... then nothing needs to be butchered at all
    with the stock radio, check for ign power at the radio, but with the radio actually plugged in so the data lines are intact...
  3. #13
    Oct 2004
    NY
    so scott_fx, does that mean your rap isn't functioning anymore either? what about your onstar?
  4. #14
    Feb 2006
    Do not use a test light on a radio that is controled by the bcm. You will short the data line and thats not to good! Remove the hush panel and the panel on the end of the dash. The bcm is located at the end of the dash with three connectors. I have provided the pinouts. Pin 23 on connector 1 is switched accy. Do yourself and your expensive car a favour and buy a digital multimeter before you touch anything because if things go sour no dealer on the planet will help you with warranty. Trust me I am a manager at a company that has the cotract to repair delco electronics.
    Body Control Module (BCM) C1•
    52-Way F AMP (BK)
    Pin Wire Color Circuit No. Function
    1 BK 860 Wiper High Speed Relay Control
    2 WH 1459 Security System Sensor Supply Voltage
    3 PK 1439 Ignition 1 Voltage
    4 BK 28 Horn Relay Control
    5 -- -- Not Used
    6 BK 707 RAP Relay Control
    7 BK/WH 1969 Headlamp High Beam Relay Control
    8 D-GN/WH 1317 Fog Lamp Relay Control
    9 PK/WH 1970 Headlamp Low Beam Relay Control
    10 WH 1080 Park Lamp Relay Control
    11 YE 749 Security Indicator Control
    12 GY 91 Wiper Relay Control
    13 YE 196 Windshield Wiper Motor Park Switch Signal
    14 BK 1835 Security System Sensor Low Reference
    15 L-GN/BK 1137 DRL Ambient Light Sensor Signal
    16 L-GN 526 Stop Lamp Switch Signal
    17 BK 1750 Ground
    18 -- -- Not Used
    19 BK/WH 151 Ground
    20 BK 1950 Ground
    21 YE 5 Crank Voltage
    22 PK 1239 Ignition 1 Voltage
    23 BN 1141 Ignition 3 Voltage
    24 TN 185 Low Washer Fluid Indicator Signal
    25 WH/BK 644 12-Volt Reference
    26 PK/BK 109 Hood Ajar Switch Signal
    27 GY 598 10-Volt Reference
    28 BK 552 Low Reference
    29 BN/WH 230 I/P Dimming Return
    30 PK 1444 I/P Dimming Control
    31 RD/WH 812 I/P Dimming Voltage Reference
    32 -- -- Not Used
    33 L-GN 5077 Low Reference
    34 BN/WH 1571 Traction Control Switch Signal
    35 -- -- Not Used
    36 PK/BK 1597 Courtesy Lamps Switch On Signal
    37 BK/WH 1455 Keyless Entry Program Enable Signal
    38 L-GN 1037 BCM Class 2 Serial Data
    39 WH 17 Stop Lamp Switch Signal
    40 L-GN 80 Key In Ignition Switch Signal
    41 L-BU/WH 1314 Left Front Turn Signal Lamp Supply Voltage
    42 D-BU/WH 1315 Right Front Turn Signal Lamp Supply Voltage
    43 GY/BK 690 Courtesy Lamp Supply Voltage
    44 OG 1732 Inadvertent Power Courtesy Lamp
    45 -- -- Not Used
    46 OG 340 Battery Positive Voltage
    47 RD 228 Windshield Washer Pump Control
    48 GY 8 Instrument Panel Lamp Supply Voltage
    49 D-GN/WH 1135 A/T Shift Lock Control Solenoid Supply Voltage
    50 OG 240 Battery Positive Voltage
    51 OG 2440 Battery Positive Voltage
    52 OG 1240 Battery Positive Voltage
    Body Control Module (BCM) C2
    • 52-Way F AMP (BK)
    Pin Wire Color
    Circuit
    No. Function
    1 -- -- Not Used
    2 RD/BK 780 Driver Door Lock Switch Lock Signal
    3 RD/BK 744 Rear Compartment Lid Ajar Switch Signal
    4 D-BU 245 Passenger Door Lock Switch Unlock Signal
    5 L-GN/BK 748 Right Rear Door Ajar Switch Signal
    6 YE/BK 1181 Right Rear Door Open Switch Signal
    7 L-BU/BK 747 Left Rear Door Ajar Switch Signal
    8 L-GN 1177 Right Front Door Open Switch Signal
    9 OG/BK 233 Park Brake Switch Signal
    10 -- -- Not Used
    11 OG/BK 781 Driver Door Lock Switch Unlock Signal
    12-14 -- -- Not Used
    15 L-BU 263 Tamper Switch Signal
    16 WH 193 Rear Defog Relay Control
    17 BK/WH 746 Right Front Door Ajar Switch Signal
    18 D-BU/WH 1179 Left Rear Door Open Switch Signal
    19-21 -- -- Not Used
    22 L-GN 1123 Door Lock Key Switch Lock Signal
    23 WH 5075 Current Sensor Voltage
    24 PU 1124 Door Lock Key Switch Unlock Signal
    25 TN 126 Left Front Door Open Switch Signal
    26 GY/BK 745 Left Front Door Ajar Switch Signal
    27-29 -- -- Not Used
    Service Information Page 3 of 6
    30 WH 17 Stop Lamp Switch Signal
    31 L-BU 244 Passenger Door Lock Switch Lock Signal
    32-34 -- -- Not Used
    35 YE 2080
    Driver Heated Seat Cushion Temperature Sensor Low
    Reference (KA1)
    36 PK 2435
    Passenger Heated Seat Cushion Temperature Sensor Low
    Reference (KA1)
    37 YE/BK 2079 Heated Seat Cushion Temperature Sensor Signal (KA1)
    38 GY 2434
    Passenger Heated Seat Cushion Temperature Sensor Signal
    (KA1)
    39 TN/WH 2430 Passenger Heated Seat Relay Control (KA1)
    40 PU 2477 Driver Heated Seat Relay Control (KA1)
    41 -- -- Not Used
    42 L-GN 24 Backup Lamp Supply Voltage
    43 YE 18 Left Rear Stop/Turn Lamp Supply Voltage
    44 GY 8 Instrument Panel Lamp Supply Voltage
    45 L-BU 1344 Trunk Release Control
    46 TN 694 Driver Door Lock Actuator Unlock Control
    47 -- -- Not Used
    48 D-GN 19 Right Rear Stop/Turn Lamp Supply Voltage
    49 OG 440 Battery Positive Voltage
    50 BK 550 Ground
    51 TN 294 Door Lock Actuator Unlock Control
    52 GY 295 Door Lock Actuator Lock Control
    Body Control Module (BCM) C3
    • 18-Way F AMP (BK)
    1-3 -- -- Not Used
    4 L-BU/WH 1414 Left Turn Signal Switch Signal
    5 L-BU 1714 Windshield Wiper Switch Low Signal
    6 L-GN 696 Cruise Control Cancel Signal
    7 WH 103 Headlamp Switch Headlamps On Signal
    8 BN/WH 301 Park Lamp Switch On Signal
    9 BN 738 Horn Switch Signal
    10 L-BU 1872 Exterior Lamps Off Input
    11 OG 192 Front Fog Lamp Switch Signal
    12 PU 524 Headlamp Dimmer Switch High Beam Signal
    13 PK 94 Windshield Washer Switch Signal
    14 BN 1356 Flash To Pass Switch Signal
    15 BK/WH 1251 Ground
    16 TN 2144 Hazard Switch Signal
    17 D-BU/WH 1415 Right Turn Signal Switch Signal
    18 L-GN 1715 Windshield Wiper Switch High Signal
  5. #15
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by turbocad6 View Post
    rap wasn't important to me. there are modules from pac-audio and top-down tech that will allow you to retain rap but i didn't see a need for it. as far as onstar...i only have a c5...no onstar :-( though i dont think i'd use it either :-)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  6. #16
    Nov 2006
    tyman, thanks for all the info. One question though, what do you mean by hush panel? I do have a good digital multimeter. Couldn't I just splice into the acc line off of the stereo?
    What about the onstar module, is there anything off of that that I could use?
    I didn't realize that it was going to be this big of a pain just to run a remote turn on lead
  7. #17
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by derekmac View Post
    if it's active then yes, thats the best place to do it, but i thought you said it wasn't active? if you get the rap/onstar module then it should reactivate the acc lead iirc
    M10k
    My Car Pc Install
    My Boat Pc worklog
  8. #18
    Nov 2006
    when I first tested it, I had everything unplugged, and by the sounds of it, having everything unhooked turns the acc wire off. I'm using the factory deck, so I shouldn't need any other modules correct? The system works the way it should when it's all hooked up, everything stays on when the key is removed until the door is opened, and the stereo won't turn on until the key is turned on.
    Just to make sure I don't hurt anything, when testing for the acc wire with the multimeter, put the negitive terminal on the ground then try the different wires? What setting should the meter be on?
  9. #19
    Dec 2004
    Los Angeles Ca
    oh... if you're keeping the head unit then yeah, just tap off hte acc lead. set the multimeter to dc voltage and you should be good to go.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  10. #20
    Feb 2006
    Derekmac
    The hush panel is the panel directly under the driver's side dash. Use a bosh 5 connector style relay and connect as follows: ploe 85-ground,pole 86-accy(from connector at bcm), pole 30-+12v battery from bcm,pole 87-to amp turn on connector. This way the amp will turn on and off with the ign key. And you will not damage any control modules.
    The factory radio is controled by class2 data line and therefore there is no accy voltage at the radio. The electronics in your vehicle are very delicate.
    If you need anymore help just pm or ask here.
    peace.
  1. Replies: 8
    Last Post: 02-14-2006, 07:43 PM
  2. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 02:56 PM
  3. Wiring in dash screen: How-to...
    By marzman in forum LCD/Display
    Last Post: 05-29-2005, 08:38 PM
  4. Wiring Xenarc to wiring harness?
    By deftones8769 in forum Power Supplies
    Last Post: 04-10-2005, 10:07 AM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
