tell me about it, gone are the good old days of quick and easy wiring. I think I'll put a toggle switch in the center console to turn the amp on and off, the wife doesn't really care to have the sub anyway.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
This might help as well
http://www.installdr.com/Harnesses/GM-Wiring.pdf
^^ Wrong wiring, that's for pre data line wiring. Hold on, let me see if i have access to the wiring information for the GMOS04
For rem turnon power, the pink line in the ign harness (under dash, should be a larger wire) is switched 12v.
Left Rear + Brown
Left Rear - Yellow
Right Rear + Dark Blue
Right Rear - Light Blue
The vehicle in an'05 there is not an option for power ant from factory, so no turn on lead. The way I described a sollution is the easiest.
^^ either way, the ignition line in those cars are huge. Last i checked they're 10ga, i forget but that was a month or two ago. He doesn't need to run a relay, the rem. turnon doesn't draw that much current.
And i meant to tap into the wire, not completely disconnect it![]()
...yeah, but from what I normally find, even if a particular car don't have a power antenna, the radio itself usually does have a terminal, even if theres no lead in the plug... as the same radio can be used in many different models.... don't know about 05's though tbh... but no power antenna option don't always mean the radio has no lead for it...
your way can never be "the best" way, simply because "the best" way wouldn't keep the amp on while the radio is off.... not saying that's terible, but not the best either... the best way will have the amp come on after the radio to avoid turn on pop....![]()
